New MIT Cable Demo/Review Program?
    treitz3 Posts: 20,119
    edited May 2013
    Oh, no, no, no. No issues like that. I'll contact Lisa per your suggestion. Thank you, sir.
    F1nut Posts: 52,005
    edited May 2013
    Bump...
    F1nut Posts: 52,005
    edited May 2013
    *Cough*
    There are hitting the streets now, more info.....http://www.mitcables.com/
  • bobsauto49
    bobsauto49 Posts: 973
    edited May 2013
    *Cough*
    They are hitting the streets now, more info.....http://www.mitcables.com/
    Fixed it! Im in! Let me know! Id be interested in mid to higher end models! JMO
    "Everything I ever did in my life worthwhile I caught hell for"
    F1nut Posts: 52,005
    edited May 2013
    Great and thanks for the correction. I saw that after the edit time expired.
    F1nut Posts: 52,005
    edited December 2013
    Round 5 featuring MIT's new StyleLine SL series cables will be starting in the very near future, so stay tuned.
    I'm fairly certain at this point there will be two demos going at the same time, a US 48 states demo and a Canadian demo......I need my head examined.
    What I'm thinking right now as follows;
    (1) 10 ft. pair of StyleLine SL-12 speaker cables (single runs)
    (1) 10 ft. single Styleline SL-12 speaker cable (center channel)
    (2) 1 meter pairs of StyleLine SL-8 RCA interconnect cables
    (1) 2 meter StyleLine Plus USB cable
    (1) 2 meter HDMI cable
    I think that should cover folks that want to demo these cables in their 2 channel music or HT rigs along with computer/server based systems.
    I'm open to suggestions.
  • zane77
    zane77 Posts: 1,696
    Jesse, put me in I would love to try these even though it would mean moving my equipment around because the cables would be a little on the short side. I would really like to try these after all of the comments I have read about the other MIT cables.
    Two Channel
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I could do with that hdmi to bridge between my perfectwave mk2 dac and ps audio perfectwave transport. The usb would be good to see if it takes down the wireworld platinum and putt them up against wireworld platinum ic's. The speaker cables could also go head to head against my wireworld silver eclipse. gold eclipse and the MIT oracles. Ohhh what a fund week that would make for comparisons running the premium tube mono'sfrom primaluna using that new BAT preamp I scored from bill...... in other words, COUNT ME IN!!!
  • Jhayman
    Jhayman Posts: 1,548
    OH YA...Please and Thank You
    F1nut Posts: 52,005
    hrm sounds enticing, however the only cables I'd be able to test would be the pair of speaker cables, the interconnects and the HDMI cable.
    That's fine, I am just trying to have something for everyone.
    Talk to me people, is that list good or would you like something else, different series, different lengths, different quantities, etc.?
    txcoastal1 Posts: 13,519
    nbrowser wrote: »
    I'm no MIT expert, but since S3 speaker cables are expensive and it was recommended to not go for the highest end in case it didn't work for me, I'd have no issues with the entry level type cables. It's all about discovery with this hobby I've found.
    They are not entry level cables my friend
    gudnoyez Posts: 8,174
    Would this be a demo with no obligations? I would be interested for my revamped HT after my basement remodel or for one of my two channel systems. Is this up and coming? I would love to see how these would make a difference in one of my systems, if I like a less expensive set of what they offer would be right up my alley as I have spent quite a few dollars as of late on remodel and stuff on the basement Ht upgrade.
    F1nut Posts: 52,005
    The only obligations are you MUST write a review here on the forum and you have to ship them to the next person on the list. That's it.
    Yes, I'll get things rolling after the first of the year.
    F1nut Posts: 52,005
    txcoastal1 wrote: »
    The StyleLine SL cables are MIT's entry level series.
    Since when are the MIT entry level $1200 or am I reading this wrong
    http://www.mitcables.com/available-in-stores/speaker-interfaces/styleline-sl-12-speaker-interface.html
    Then I sir would be interested some time middle next month as I go to Boise Idaho for a few days and plan on ordering an Oppo after I get back thanks for the opportunity should it be possible.
    nbrowser wrote: »
    txcoastal, and this is would a learning experience. Is that a bad thing ?
    I don't know much about cables other than something about you can't solder with certain copper etc. But I digress, I'm wet behind the ears in this now. Why not try some stuff in my own system to see if it makes better or worse. Never know til you plug something in as I've found.
    No not at all, I always believe take every opportunity to demo and don't rely on other peoples opinions but use them as guide lines in your search. It took me 2 years to piece together my first 2chnl rig.
    I also, drove around to a dozen plus dealers all over Texas and went to different shows to get my ears on gear.
    F1nut Posts: 52,005
    txcoastal1 wrote: »
    As I said, the StyleLine SL SERIES is MIT's entry level cable. The StyleLine SL 5 would be the least expensive.
    Are they entry level compared price wise to Monoprice or BJC? No, but they are not just cable either.
    F1nut Posts: 52,005
    gudnoyez wrote: »
    That's great, Steve. I'll get your info once things get rolling.
    Not knock the system, as those who would not normally get a chance to listen to a higher end cables need to get on board.
    I was referring to the SL12 demo cables you are offering
  • polkfarmboy
    I was thinking these were the 10 grand speaker cables?
    F1nut Posts: 52,005
    txcoastal1 wrote: »
    I see. My intentions are to offer the TOTL entry level cables as a sort of middle ground between the SL 5's and the next level up, which would be either the SL-Matrix, Matrix HD or the Shotgun. We demoed the Shotgun series the last time and since this is MIT's new series with new technology it seemed only logical.
  • xsmi
    xsmi Posts: 1,804
    Jesse, I'm in. And the complement of cables you have would cover my system fine as I only have a 2 - channel system. Maybe a to slink or coaxial to DAC cable would be the only addition I'd make. I don't need one though.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
    F1nut Posts: 52,005
    edited January 2014
    Ok folks, both the USA and Canada demo programs are a go. I've posted threads for both in the 2 CHANNEL section. Please read the entire thread and if you are interested contact me via PM or email.
    The actual demos will not start until about the end of January, but if you sign up now you'll get them that much quicker.
