rear speaker suggestions
fjross
I finished a restroration on a 71 442 convertible. I didn't want to hack up any of the new interior panels. I have after market kick panel with Polk db651 since they were the only ones that would fit due to the depth and can be changed back to stock panel with a few screws. I fitted a Kenwood KDC-X794 in my 8 track housing. I pre ran RCA jacks from the head unit to the truck as well as the remote wire and power feed to the battery. I just picked up a Polk PA D5000.5 and a db1212 sub that I plan on mounting in the trunk. I was wondering if anyone would have any suggestions on a pair of 4ohm bookself speakers that I could use to put on the rear seat. The other alternative would be to use 6x9 with enclosures. I want to go this route so I can remove the rear speakers if I go to a car show and store in the trunk. My first choice would be the bookself if they were small enough.
Dave
Dave
Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
MIT 3.3 Shotgun biwire speaker interface
MIT 3.3 Shotgun XLR interconnects
Polk 2.3TL's Gimpod boards/F-1 modded crossovers/dynamat/JB weld/Larry's rings/Blackhole 5 strips
Polk 3.1 TL's mint/stock (purchased new)
Polk SDA-2's
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
Polk SDA-2's
Post edited by fjross on
Nice!
Your car should have factory holes for 6X9's behind the back seat. You mount the speakers pointing backwards towards the area for the convertible top. -
Pics please... those 442 Cutlasses are one of my favorite cars. Hopefully you have the 455 version?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I will post some pics of the car when I get back home Sunday. Viking bllue convertible with 455 dual gate and W-25 induction hood. It was a 5 year body off restoration on a numbers matching car.nooshinjohn wrote: »Pics please... those 442 Cutlasses are one of my favorite cars. Hopefully you have the 455 version?Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
Polk SDA-2's -
I was looking for a better spot then behind the seats forward the top well. I think they would be muffled back there.Nice!
Your car should have factory holes for 6X9's behind the back seat. You mount the speakers pointing backwards towards the area for the convertible top.Mcintosh MC-501 mono blocks
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
Polk SDA-2's -
Here are a few pics. The Land Cruiser mine also.nooshinjohn wrote: »Pics please... those 442 Cutlasses are one of my favorite cars. Hopefully you have the 455 version?
Mcintosh C-45
Mcintosh MVP-871
PS AUDIO AV5000
Polk SDA-2's
