Can't decide - help me
So I had another thread where you guys recommended the polk rtia7 and I was et on those until I found out about the infinity.
Here is what is bothering me, I am trying to justify the cost vs. what I am getting.
I can get the polk for
RTiA7 - $720 / pair
RTIA6 - $355
FXIA6 - $335
Total - $1410
Infinity frys deal
P363- $244
P363 $244 surround 9 use as surround as well as the stands would cost for the bookshelves)
c351 - $200
Total - $688
I am happy with my HTIB, so wouldn't I be satisfied with the infinity which comes out cheaper. I will also add sub and the reviews say that it will be able to fill large space.
I know this is a polk forum, but do any of you have any experience with the p363 speakers.
RTiA7 - $720 / pair
RTIA6 - $355
FXIA6 - $335
Total - $1410
Infinity frys deal
P363- $244
c351 - $200
Total - $688
Post edited by sid369 on
Head to Frys and check it out to see if your getting new speakers or floor models.. They had LSi on sale weeks ago and I remember people saying at the end all they had were beat up floor models.
No idea how they sound but I guess they are 3 way speakers that remind me of the LSiM with its small mid range driver near the tweeter.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
You won't know until you listen for yourself; so going to Frys is a good suggestion. If the Infinitys sound to you just as good as you can't justify the extra cost of the Polks, there's your answer!
You could save some coin on Polk's eBay store (refurbished) if you don't mind slightly different models.
I got these:
Pair of rti10's (similar to rtia7) for 658 & rti5 (similar to rtia6) for 225.
According to some folks, however, the rti's and rtia's sound different even though they have (presumably) identical circuitry. Different body styling, though. I have no frame of reference as I haven't listened to either one, yet. -
RTiA7 - $720 / pair
RTIA6 - $355
FXIA6 - $335
Total - $1410
Infinity frys deal
P363- $244
c351 - $200
Total - $688
The price is bothering you right now but after you settle for the cheaper ones, your "What if's" will bother you later on. Got to love the upgrade bug.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Rti10 cover is different than A7, as is the whole line fwiw- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Crossover- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Check out the motion 12 from Martin Logan.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882981006B&W CM9Classé Sigma -
You can't be that happy otherwise you wouldn't be in the market for new speakers, right?
So what do you plan on using to drive whatever speakers you buy?Political Correctness'.........defined
President of Club Polk -
Hopefully it won't be the receiver from the HTIB.
The Polk system your looking at will fill a larger room with sound. If you have a HTIB now and your room is on the smaller side it may be over kill for you. Also the costs of a good receiver might be something you haven't figured on either. Since your currently happy with your HTIB, maybe best to wait on buying anything and do more home work, save a few more coins.HT SYSTEM-
lsi 9's -
I heard the 1st gen amd thought they were just "ok" but I hear these are better. I really want to listen to this newer line.Check out the motion 12 from Martin Logan.
I say go listen to the Polks, the Infinitys, and the JBL Studios and let your ears decide. How often do you buy speakers?2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
You could save some coin on Polk's eBay store (refurbished) Got my Monitors from Polk E Bay store & they were brand spanking new in the original packing. Probably just overstock. My experience with the Polk on line store has been extremely positive.
stop focusing on price and start focusing on sound. If you can get your ears on them choose the one that you like the sound of the most.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
http://stores.ebay.com/Polk-Audio-Direct
you can go here and see if any of these float your boat....
Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes: -
I just got mine today. They look brand new. -
I wish it was possible like back in a day to just walk into a local store and hear a bunch of different gear.. worlds a different place today then 10 years ago thanks to the internet.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
