Polk Monitor 5 updates
Joe108
I have a pair of polk monitor 5's and I want to undate the tweeters and crossovers, but I can't seem to find out what I need and where to get it, thanks, Joe
Post edited by Joe108 on
Hello Joe,welcome to the forum.This should get you started.
http://www.soniccraft.com/products.htm
http://www.polkaudio.com/forums/showthread.php?51420-Monitor-5b-s-x-over-upgrade-w-pics&p=614789#post614789 -
Thank You
I must be thck or something but I can't seem to make heads or tails from these two sites, help.
Hello Joe sorry to confuse you,the first link is to soniccraft.It is one of many places to buy your parts for your upgrade.The other is from one of our long time members who did the upgrade you want to do.For your tweeters call customer service number is at the top right of the page tell them you want to upgrade your monitor 5 tweeters they will help you out.You will also need capacitors and resistors.for the crossover upgrade.You can find what parts you need to buy here.Post #2 for monitor 5s
http://www.polkaudio.com/forums/showthread.php?72401-POLK-AUDIO-Speaker-Parts-List
Hope this clears things up for you,im sure others will chime in also.
Dan -
make sure you get the values on YOUR cross overs and not off the list, this way you're going to get the correct items. just to double check as yous may be slightly different.
Thanks for all the help everyone, Joe
Nike42eet reported spammer
lol, after only 4 years, the link is dead. This seems to be the one which was and is again. http://forum.polkaudio.com/discussion/72401/polk-audio-speaker-parts-list
