Shipping speakers, help needed
HTguru1982
I am shipping a pair of speakers to a fellow Polkie and was wondering if my packing job is sufficient. If not, what should I do differently? I am using packing foam that is used for laptop computers but not sure if it's strong enough for speakers. Here are pics:
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Post edited by HTguru1982 on
That isn't going to work, the foam is too soft. Go to Home Depot or Lowe's and buy the pink or blue hard foam sheet insulation. It comes in 1/2", 3/4" and 1" thickness. You want to have at least 2" of it top, bottom and all sides. Two inches is the minimum requirement of UPS and FedEx. Part of the idea is to not allow the item to move at all and the 2" of foam will help prevent damage from being dropped. I use it all the time and I've never had an item get damaged. I should mention the foam isn't cheap, so you have to figure that into the shipping cost.Political Correctness'.........defined
President of Club Polk -
HTguru1982 wrote: »I am shipping a pair of speakers to a fellow Polkie and was wondering if my packing job is sufficient. If not, what should I do differently? I am using packing foam that is used for laptop computers but not sure if it's strong enough for speakers. Here are pics:
here are some pics of the packing process first a bunch of bubble wrap layed in the bottom of the first box 20 x 12 x 20 then the amp itself bubble wrapped then extra bubble wrap on all sides top and bottom to fill it up then a 2 inch foam sheet cut to fit in the bottom of the 2nd box 25 x 16 x 25 then the sides with 2 inch foam sheets weight is now 65 lbs total cost of packing supplies $50.00..... $20.00 for a large roll of bubble wrap $16.00 for a sheet of 2 inch foam $5.00 for a 20 x 12 x 20 box $8.95 for a box 24 x 20 x 24 cut to size and tape is pretty much free
1/1/2 sheets are around $12.00 for a 2 foot X 8 foot sheet and 1" sheets are around $10.00 the same size
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all -
I had a feeling it wouldn't work. Thanks for the info. Looks like I'm making a trip to Home Depot.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Subwoofer: SVS PB10-ISD -
If you don't double-box them, you should consider at least putting a stiff piece of cardboard against the grilles so that the bubble wrap can't press the grilles in against the drivers.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
Trust this - it works 100%. I know.That isn't going to work, the foam is too soft. Go to Home Depot or Lowe's and buy the pink or blue hard foam sheet insulation. It comes in 1/2", 3/4" and 1" thickness. You want to have at least 2" of it top, bottom and all sides. Two inches is the minimum requirement of UPS and FedEx. Part of the idea is to not allow the item to move at all and the 2" of foam will help prevent damage from being dropped. I use it all the time and I've never had an item get damaged. I should mention the foam isn't cheap, so you have to figure that into the shipping cost.Michael
NORTH of 60° -
As the person buying these speakers, thanks for the attention to detail! Hope I gave you enough for the shipping so you aren't out of pocket! :biggrin:Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
