pro power amp on a HT
stuntman3
I'm trying to deside between yamaha P2500s rated 350w/channel. Or P3500s rated 550w/channel 8ohm. I'm using RTi A7 for fronts. And I have an avr with pre outs
Post edited by stuntman3 on
Why a pro amp as they dont have clean power? How much are these amps as I'm sure you could find an equivalent in price thats better
You say that... but there are a lot of people around the various forums finding that amps like the Crown XLS series are astoundingly capable powering home theater speakers. I'm running an XLS-1500 for my subwoofer and Buttkicker, but I've seen a lot of people using these newer class D Crowns as 2-channel amps, with good results. Can't speak for the Yamahas the OP is looking into, but I certainly wouldn't discount pro amps.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
I own the Yamaha P2500. It's quiet, it powers the LSi 9's more than adequately. Replaced my Marantz Mono-Blocks (one developed hum) and the imaging, soundstage, overall presentation are excellent. I listen to a lot of classical, some blues, rock, jazz. Percussion has oomph, cymbals, bells, etc sound natural with very good decay.
Others have been giving thumbs up to the Crown XLS DriveCore series in the fidelity department alone.
The Yamaha has plenty of clean power. You could do what I did and go to Guitar Center and check all this stuff out. They have a really good / easy return policy also. Staff was more than willing to answer questions and help out. Heeding the suggestion of trying the pro-audio route for both my amp and now my pre-amp really worked out. -
I read a lot of positive reviews about pro power amp in a HT. I just want to know if the 500w is a good choice
It may go unused. 350 watts is a lot of power. 700 watts gets you only 3dB more for comparison. Most AVR's increment in 1/2 dB steps. -
Thanks guys ill go with 350w
Interesting.. Would not think one would want to use that for there home speakers. Does it auto sense power and turn on or would you have to turn it on and off all the time?Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Most don't with good reason.Political Correctness'.........defined
President of Club Polk -
Would this be one of those times that a Emotiva amplifier would beat out something else?
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Makes sense to me that pro amps could sound good with certain home/home theater speakers. It's all in the synergy. For instance a cheap yamaha A-S500 or cheap Emotiva UPA-200 sounds worlds better with my home stereo speakers than did a Jolida 801 all tube amp. It's all about the match and mate. Starting to realize that amps aren't necessarily better than other ones, because you're not buying them to function within a vacuum. They have to interact within your existing system which is comprised of numerous components. So the "this amp is no good, but this one is" is a misguided notion. Not only that but your ideal sound has nothing to do with someone else's. As much as it sucks, you really do have to listen and discover what works best with your stuff ... to your ears. I've wasted plenty of money taking the advice of reviewers and message board pundits. Just as with music, there is no good or bad, there's what you like and what you don't like.
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
I agree with you on most of that, but there is bad music...
That is why you don't see just any pro-audio amp recommended. Just like not all consumer amps are going to be everyones cup of tea. I have read several different posters swear off Carver (I know Dorokusai does) and Adcom as example.
I'm happy my LSi's match up rather well with my Yammy. I think people need to be encouraged to try them out. If they don't work out just return the unit and get your money back. There was even a poster here that switched up his two Thresholds (I think they were Thresholds) for a Crown XLS DriveCore to power his SDA's and was pleasantly surprised. Not that the effort was appreciated for posting about it. -
Don't listen to anyone who tries to tell you what is good and what is bad. The very concept is fundamentally flawed. They have NO idea what you enjoy hearing and what you don't enjoy hearing. If they're lucky they have a reasonable grasp on what they enjoy hearing. What's important is that it sounds good to you and that it lasts. If the pro amp meets the criteria, then a pro amp it is. Pretending to enjoy someone else's favorite brand, make and model of amp would be a shame, particularly if it's expensive and breaks down on you. What's good for the goose isn't necessarily good for the gander.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
I don't. There are bad amps and there are good amps. Synergy plays a role but a good amp will almost always outshine the bad one on a revealing system. I wouldnt fret on throwing a pro amp on entry level gear, but would be reserved if it came to something as revealing as the lsim, a speaker able to show the nuances in the music or track.
This isn't the constitution; not all watts are created equal.
You might be surprised at the Crown I-Tech or Lab Gruppen with the Digital Look Ahead tracking. -
A bit of interesting reading for those considering pro amps:
http://www.andrew-robinson-online.com/review-crown-xls-drivecore-series-amplifier/Equipment list:
Emotiva XPA-3 amp
Possibly. But championing the performance of pro amps as a whole based off a few exceptions bugs me. While there are duds in home amp design, the majority of them have the same design properties in mind, thereby usually giving a respectable product for the home.
You're not arguing with anything I said though, so we're good right? :cool:
I was basing my response on " I wouldnt fret on throwing a pro amp on entry level gear, but would be reserved if it came to something as revealing as the lsim, a speaker able to show the nuances in the music or track.
Your statement/claim seemed overly broad as to overreach. The OP was asking about a specific amp. One I own with prior experience being a Yamaha AVR and then Marantz mono-blocks. I don't see where in this thread the "championing of pro amps as a whole" persisted or even originated. That is where I had a question. -
FYI, Lexicon who is owned by Harman International, also uses the Texas Instruments based DriveCore class-D amp set in their DD-8 amp, which used in the Crown XLS amps. The technology was developed in-house at Harman partnering with Ti, and is being using throughout their lines; including active JBL studio monitors.
While it hasn't been in this thread, it is the general tone you give off on every post concerning pro amps.
Do you care to go through my posts and corroborate the 'general tone'? I doubt it can be substantiated. I even started a thread asking about peoples experience here with specific pro-audio amps that did the trick.
The only one going off on a general tangent (at least in this thread) is you. Two specific amps (not even brands) have been mentioned.
Look if you don't like pro-amps for whatever reason that is fine. I don't even seeing you putting down the suggestions made. But could you stop with baseless accusations? If what you said had merit I would expect some posts of mine to be quoted. -
If it had mentioned the specific amp in the title, I would've stayed away.
You could have read the original post and still shied away from the thread.People search this stuff and when they see the 'pro amp' header, they're going to assume things.
Just so this is straight in my mind: You are making assumptions about what other people are going to assume from "pro power amp on a HT"? :eek: Trying to close the loop on your logic on that count.I'm trying to kill that assumption, not argue about your own beloved pro amp. There are exceptions to every rule, but I'm trying to dissuade others from starting their search for a Lexus at a Kia dealership.
The only assumption need killing is your initial assumption that the thread title is going to lead people to look for a Kia at a Lexus dealership.
Also the quip about 'beloved pro-amp' isn't needed. I took zero risk in evaluating the PS2500 and was pleasantly surprised. If the Yammy or Crown aren't the end all be all well neither are my LSi 9's. -
Look over there!!!
Bunnies!!!! -
http://www.andrew-robinson-online.co...ies-amplifier/ this is a nice link. Thanks bro. Some people don't take time with their giyer sometimes with a few tweak and sometimes it can days 2 get it ryt.
stuntman3: I think you could be having a stroke! :eek: If you're near someone else right now and you're comprehending this, point it out to them. It may not be too late to get you help! -
Must be the red wine talking. Gear I ment
While it hasn't been in this thread, it is the general tone you give off on every post concerning pro amps.Habanero Monk wrote: »Do you care to go through my posts and corroborate the 'general tone'? I doubt it can be substantiated.
The sound of crickets... -
Habanero Monk wrote: »The sound of crickets...
This squabble does not add to the informational dialog that some would hope to gain from this thread. -
Neither do baseless accusations but feel free to take on the person wronged instead of never replying to the person that made the accusation. I know how cliques like to hang together regardless of merit. -
And frankly, I am done trying to have a logical and factually based conversation with you because it has proven time and time again to be a wasted effort.
What? Let me know when logic and facts are brought into it. I would love it if it got there sooner. It's takes 3 pages just to steer it there. People want to say Brand X cable all turns green. I point out what are %'s and it takes that long to get to the point of %'s instead of blanket statements.
Your post is reality distortion at it's best all while ignoring the fact a claim was made that can't be backed up. If it could be backed up it would have been. Get it? Or do you just get tired of having broken logic pointed out? -
Well no, you assumed percentages because you have no facts to back that speculation. The fact is that there are too many examples of Monoprice cable turning green to ignore.
All this effort you're putting forth to tell people how and what to post, then reporting them when it's something that doesn't fit your view of the world is beyond ridiculous.Political Correctness'.........defined
K I'm bc. I bought a crown XlS2000 nd a 2way stereo converter. I hook up an old pair of tsi 400 guess what?those **** head woke up now I feel like I've been holding them bc. Now I'm thinking of making a DiY sub adding another pro amp. I have a JBL 4000W car sub dual voice coil 6ohm-W12GTI MKII. Any suggestions?
