pro power amp on a HT
stuntman3
stuntman3 Posts: 27
edited May 2013 in Electronics
I'm trying to deside between yamaha P2500s rated 350w/channel. Or P3500s rated 550w/channel 8ohm. I'm using RTi A7 for fronts. And I have an avr with pre outs
Post edited by stuntman3 on
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited April 2013
    Why a pro amp as they dont have clean power? How much are these amps as I'm sure you could find an equivalent in price thats better
  • kuntasensei
    kuntasensei Posts: 3,263
    edited April 2013
    You say that... but there are a lot of people around the various forums finding that amps like the Crown XLS series are astoundingly capable powering home theater speakers. I'm running an XLS-1500 for my subwoofer and Buttkicker, but I've seen a lot of people using these newer class D Crowns as 2-channel amps, with good results. Can't speak for the Yamahas the OP is looking into, but I certainly wouldn't discount pro amps.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Habanero Monk
    Habanero Monk Posts: 715
    edited April 2013
    I own the Yamaha P2500. It's quiet, it powers the LSi 9's more than adequately. Replaced my Marantz Mono-Blocks (one developed hum) and the imaging, soundstage, overall presentation are excellent. I listen to a lot of classical, some blues, rock, jazz. Percussion has oomph, cymbals, bells, etc sound natural with very good decay.
    Others have been giving thumbs up to the Crown XLS DriveCore series in the fidelity department alone.
    The Yamaha has plenty of clean power. You could do what I did and go to Guitar Center and check all this stuff out. They have a really good / easy return policy also. Staff was more than willing to answer questions and help out. Heeding the suggestion of trying the pro-audio route for both my amp and now my pre-amp really worked out.
  • stuntman3
    stuntman3 Posts: 27
    edited April 2013
    I read a lot of positive reviews about pro power amp in a HT. I just want to know if the 500w is a good choice
  • Habanero Monk
    edited April 2013
    stuntman3 wrote: »
    It may go unused. 350 watts is a lot of power. 700 watts gets you only 3dB more for comparison. Most AVR's increment in 1/2 dB steps.
  • stuntman3
    stuntman3 Posts: 27
    edited April 2013
    Thanks guys ill go with 350w
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Interesting.. Would not think one would want to use that for there home speakers. Does it auto sense power and turn on or would you have to turn it on and off all the time?
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
    F1nut Posts: 52,008
    edited April 2013
    eclypse wrote: »
    Most don't with good reason.
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Would this be one of those times that a Emotiva amplifier would beat out something else? :)
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • Loud & Clear
    Loud & Clear Posts: 1,538
    edited April 2013
    Makes sense to me that pro amps could sound good with certain home/home theater speakers. It's all in the synergy. For instance a cheap yamaha A-S500 or cheap Emotiva UPA-200 sounds worlds better with my home stereo speakers than did a Jolida 801 all tube amp. It's all about the match and mate. Starting to realize that amps aren't necessarily better than other ones, because you're not buying them to function within a vacuum. They have to interact within your existing system which is comprised of numerous components. So the "this amp is no good, but this one is" is a misguided notion. Not only that but your ideal sound has nothing to do with someone else's. As much as it sucks, you really do have to listen and discover what works best with your stuff ... to your ears. I've wasted plenty of money taking the advice of reviewers and message board pundits. Just as with music, there is no good or bad, there's what you like and what you don't like.
    Two Channel Setup:
    Speakers: Wharfedale Opus 2-3
    Integrated Amp: Krell S-300i
    DAC: Arcam irDac
    Source: iMac
    Remote Control: iPad Mini
    3.2 Home Theater Setup:
    Fronts: Klipsch RP-160M
    Center: Klipsch RP-160M
    Subwoofer: SVS PB12NSD (X 2)
    AVR: Yamaha Aventage RX-A2030
    Blu Ray: Sony BDP-S790
    TV Source: DirecTV Genie
  • zingo
    zingo Posts: 11,258
    edited April 2013
    I agree with you on most of that, but there is bad music... :)
  • Habanero Monk
    edited April 2013
    That is why you don't see just any pro-audio amp recommended. Just like not all consumer amps are going to be everyones cup of tea. I have read several different posters swear off Carver (I know Dorokusai does) and Adcom as example.
    I'm happy my LSi's match up rather well with my Yammy. I think people need to be encouraged to try them out. If they don't work out just return the unit and get your money back. There was even a poster here that switched up his two Thresholds (I think they were Thresholds) for a Crown XLS DriveCore to power his SDA's and was pleasantly surprised. Not that the effort was appreciated for posting about it.
  • Loud & Clear
    edited April 2013
    Don't listen to anyone who tries to tell you what is good and what is bad. The very concept is fundamentally flawed. They have NO idea what you enjoy hearing and what you don't enjoy hearing. If they're lucky they have a reasonable grasp on what they enjoy hearing. What's important is that it sounds good to you and that it lasts. If the pro amp meets the criteria, then a pro amp it is. Pretending to enjoy someone else's favorite brand, make and model of amp would be a shame, particularly if it's expensive and breaks down on you. What's good for the goose isn't necessarily good for the gander.
    Two Channel Setup:
    DAC: Arcam irDac
    Source: iMac
  • Habanero Monk
    edited April 2013
    DSkip wrote: »
    I don't. There are bad amps and there are good amps. Synergy plays a role but a good amp will almost always outshine the bad one on a revealing system. I wouldnt fret on throwing a pro amp on entry level gear, but would be reserved if it came to something as revealing as the lsim, a speaker able to show the nuances in the music or track.
    This isn't the constitution; not all watts are created equal.
    You might be surprised at the Crown I-Tech or Lab Gruppen with the Digital Look Ahead tracking.
  • kuntasensei
    edited April 2013
    A bit of interesting reading for those considering pro amps:
    http://www.andrew-robinson-online.com/review-crown-xls-drivecore-series-amplifier/
    Equipment list:
    Emotiva XPA-3 amp
  • Habanero Monk
    edited April 2013
    DSkip wrote: »
    Possibly. But championing the performance of pro amps as a whole based off a few exceptions bugs me. While there are duds in home amp design, the majority of them have the same design properties in mind, thereby usually giving a respectable product for the home.
    You're not arguing with anything I said though, so we're good right? :cool:
    I was basing my response on " I wouldnt fret on throwing a pro amp on entry level gear, but would be reserved if it came to something as revealing as the lsim, a speaker able to show the nuances in the music or track.
    Your statement/claim seemed overly broad as to overreach. The OP was asking about a specific amp. One I own with prior experience being a Yamaha AVR and then Marantz mono-blocks. I don't see where in this thread the "championing of pro amps as a whole" persisted or even originated. That is where I had a question.
  • zingo
    zingo Posts: 11,258
    edited April 2013
    FYI, Lexicon who is owned by Harman International, also uses the Texas Instruments based DriveCore class-D amp set in their DD-8 amp, which used in the Crown XLS amps. The technology was developed in-house at Harman partnering with Ti, and is being using throughout their lines; including active JBL studio monitors.
  • Habanero Monk
    edited April 2013
    DSkip wrote: »
    While it hasn't been in this thread, it is the general tone you give off on every post concerning pro amps.
    Do you care to go through my posts and corroborate the 'general tone'? I doubt it can be substantiated. I even started a thread asking about peoples experience here with specific pro-audio amps that did the trick.
    The only one going off on a general tangent (at least in this thread) is you. Two specific amps (not even brands) have been mentioned.
    Look if you don't like pro-amps for whatever reason that is fine. I don't even seeing you putting down the suggestions made. But could you stop with baseless accusations? If what you said had merit I would expect some posts of mine to be quoted.
  • Habanero Monk
    edited April 2013
    DSkip wrote: »
    If it had mentioned the specific amp in the title, I would've stayed away.
    You could have read the original post and still shied away from the thread.
    DSkip wrote: »
    People search this stuff and when they see the 'pro amp' header, they're going to assume things.
    Just so this is straight in my mind: You are making assumptions about what other people are going to assume from "pro power amp on a HT"? :eek: Trying to close the loop on your logic on that count.
    DSkip wrote: »
    I'm trying to kill that assumption, not argue about your own beloved pro amp. There are exceptions to every rule, but I'm trying to dissuade others from starting their search for a Lexus at a Kia dealership.
    The only assumption need killing is your initial assumption that the thread title is going to lead people to look for a Kia at a Lexus dealership.
    Also the quip about 'beloved pro-amp' isn't needed. I took zero risk in evaluating the PS2500 and was pleasantly surprised. If the Yammy or Crown aren't the end all be all well neither are my LSi 9's.
  • lightman1
    lightman1 Posts: 10,797
    edited April 2013
    Look over there!!!
    Bunnies!!!!
  • pdxfj
    pdxfj Posts: 376
    edited April 2013
  • stuntman3
    stuntman3 Posts: 27
    edited April 2013
    http://www.andrew-robinson-online.co...ies-amplifier/ this is a nice link. Thanks bro. Some people don't take time with their giyer sometimes with a few tweak and sometimes it can days 2 get it ryt.
  • teekay0007
    teekay0007 Posts: 2,288
    edited April 2013
    stuntman3 wrote: »
    stuntman3: I think you could be having a stroke! :eek: If you're near someone else right now and you're comprehending this, point it out to them. It may not be too late to get you help!
  • stuntman3
    stuntman3 Posts: 27
    edited April 2013
    Must be the red wine talking. Gear I ment
  • Habanero Monk
    edited May 2013
    DSkip wrote: »
    The sound of crickets...
  • zingo
    zingo Posts: 11,258
    edited May 2013
    This squabble does not add to the informational dialog that some would hope to gain from this thread.
  • Habanero Monk
    edited May 2013
    zingo wrote: »
    Neither do baseless accusations but feel free to take on the person wronged instead of never replying to the person that made the accusation. I know how cliques like to hang together regardless of merit.
  • Habanero Monk
    edited May 2013
    ZLTFUL wrote: »
    And frankly, I am done trying to have a logical and factually based conversation with you because it has proven time and time again to be a wasted effort.
    What? Let me know when logic and facts are brought into it. I would love it if it got there sooner. It's takes 3 pages just to steer it there. People want to say Brand X cable all turns green. I point out what are %'s and it takes that long to get to the point of %'s instead of blanket statements.
    Your post is reality distortion at it's best all while ignoring the fact a claim was made that can't be backed up. If it could be backed up it would have been. Get it? Or do you just get tired of having broken logic pointed out?
    F1nut Posts: 52,008
    edited May 2013
    Well no, you assumed percentages because you have no facts to back that speculation. The fact is that there are too many examples of Monoprice cable turning green to ignore.
    All this effort you're putting forth to tell people how and what to post, then reporting them when it's something that doesn't fit your view of the world is beyond ridiculous.
  • stuntman3
    stuntman3 Posts: 27
    edited May 2013
    K I'm bc. I bought a crown XlS2000 nd a 2way stereo converter. I hook up an old pair of tsi 400 guess what?those **** head woke up now I feel like I've been holding them bc. Now I'm thinking of making a DiY sub adding another pro amp. I have a JBL 4000W car sub dual voice coil 6ohm-W12GTI MKII. Any suggestions?
