Carpet spikes for RTI 10's
Falke401
Falke401 Posts: 15
I recently picked up a pair of RTI 10's and they did not have any carpet spikes on them. I have been randomly searching for these speakers for a couple years and FINALLY found a set for $200. Are they universal or do I need a special type of spikes for these speakers?
They are replacing the RTI 6's and I have a CSI5 for the center. When I move and have a living room with a better setup, the 6's will be in the rear.
Thanks!
Post edited by Falke401 on
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Usually the rubber covers over the spikes. Did you check to see if you can just pull off the rubber feet and if theres a spike left? So basicly the bolt that goes into the speaker is the spike and the rubber foot just slips over it.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • polrbehr
    polrbehr Posts: 2,846
    edited April 2013
    There are actually plastic "outriggers" (don't know what else to call them?) that attach to the MDF of the speaker itself. Do you have them? The carpet spikes get screwed directly into the plastic, not into the speaker itself.
    Assuming you do have them, I believe they are 1/4-20 thread. I can check mine and see exactly if you want.
    By the way, $200 is a steal for those, I wish I paid even close to that for mine : / :eek:
    Well, thanks for the confirmation, now I don't have to tip mine over... LOL
    F1nut Posts: 51,913
    edited April 2013
    The thread pattern is 1/4-20.
    If you want some of the best available, http://www.hifiracks.co.uk/accessories/27/stainless-steel-35mm-spikes
    You will have to tell them you want 1/4-20 threads and a 20mm thread length.
  • Falke401
    Falke401 Posts: 15
    edited April 2013
    Thanks for the help. The speakers do have the plastic outriggers, but no spikes in them. I don't need the best by any means. Just something to get them off the carpet and more stable.
    F1nut Posts: 51,913
    edited April 2013
    For spikes to be effective on carpet, they must pierce the carpet. The ones I linked will do that even on the thickest of carpets. That said, you can buy the super cheap thin steel spikes at Parts Express, which will also pierce carpet, but they are not what one would call quality spikes.
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Heres a thread where people talk about where to get spikes.. Now that you know the size you need you should be in business. http://www.polkaudio.com/forums/showthread.php?141937-Where-are-people-getting-their-speaker-spikes-these-days
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • Falke401
    Falke401 Posts: 15
    edited April 2013
    Thanks for the help. I ended up ordering some from http://www.oregondv.com. It will be a few weeks before I am home to even see them, though.
  • custopper30
    custopper30 Posts: 252
    edited May 2013
    Did you end up getting a good deal on those?
    Receiver: Denon 1912
    Speakers:
    Fronts: Polk Audio Monitor 70s (x2)
    Rears: Polk Audio Monitor 50 (x2)
    Center: Polk Audio Monitor 70
    KLH Sub GFX-550
