AC regeneration under 700 USD
doctorcilantro
I've run across an interesting AC regenerator that I could use on my DAC and EL34 SET since it is a 100w max unit.
It has the ability to run:
The unit I am looking at is a copy? or original of the Monarchy Audio unit. I found this tech. was used in the Mark Levinson No.32:
http://www.stereophile.com/solidpreamps/196/index.html
thoughts? I'm ordering one...
DC
"Traditional, the power regenerator will use filter or isolation transformers. Although you can increase the S/N ratio, protect against surge but will affect the quality of the dynamic and sound field effect.
P100 use a group of 'SPECIAL CONTROL' circuit to generate perfect sine waves (AC to DC) then enlarge to 110V or 220V (DC to AC) output. This practice not only supply completely pure clean voltage and alos the damping coefficient is higher. You can switch the frequency, enhance the efficiency of of equipment power supply! Comparing to 400Hz power supply with 60Hz - P100 can output the utilization ratio of 20% more! Even comparing to 60Hz with 60Hz, P100 can output the utilization ratio of 5 to 10% more! P100 can make improvements very alarming - the sound field is width than before, deeper low frequency, high frequency can up more and became more details."
DC
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Post edited by doctorcilantro on
Is this the unit ? http://www.pricemart8.com/catalog/item/8049404/8680133.htm
If 100watts is all you need it looks like it will fit the bill.
Have not found anything negative in my search.Speakers: SDA-1C (most all the goodies)
Ham radio operators sometimes complain about the amount of interference their neighbors units generate. So if you get one, make sure that it's FCC tested.
I've got one on order, so I'll keep you posted. Where I live there is no FCC
For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
It's not about the rule, it's about all the possible interference that it may be generating.
True, but I have very few neighbors. What kind of interference? I'm not a HAM.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
doctorcilantro wrote: »I've got one on order, so I'll keep you posted. Where I live there is no FCC
No FCC???
Just this week.
FCC court case.
http://transition.fcc.gov/Daily_Releases/Daily_Business/2013/db0423/DA-13-805A1.pdf -
Speedskater wrote: »No FCC???
Just this week.
FCC court case.
Sorry I need to update my profile's location.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
That makes more sense than Tampa.
