Good tube amp needed for Polk Audio SDA 1B's
ZaPHoN
ZaPHoN Posts: 90
My Home Theater Adventure
Phase 1
I'm no audiophile, but I do take the time to do my homework and since time and $$ is in short supply these days I'm appealing to the experts here at CAM.
I just acquired a flawless set of Polk Audio SDA 1B's and I'd really like to break in the the alternative universe of Tube heaven from an entry level. So, if someone is so inclined to steer me in the right direction or has an offer that could help me on the path of tube education, I'd really appreciate it.
I'm not sure it is even possible but I'd like to keep the price around $500 and be able to actually wake these SDA 1B's up.
Note: I currently have Yamaha HTR-6180 driving the SDA 1B's. Sound quality is ok I guess and when using the 2 Channel stereo it starts to choke at about half throttle. Distortion seems to start creeping in. Of cource, friends seem to not hear it but their ears are trained to cheap crap. The dynamics are just not there. Years ago I would often stop by a friends audio store after hours just to site and listen to some vinyl through a Luxman tube amp while sipping on martini's. Thinking back to that warm fuzzy feeling I would get from that combination (minus the martini's) I can safely say I'm not there yet but still long for the day to go back in time.
Phase 2
I'm picking up a killer deal on a a set of RTA 11T's too so I'll eventually need an amp for them as well. Budget $500
Phase 3
Still looking for a crazy deal on a center channel that matches well with the Polks and a mono block tube to drive it. I suspect it would probably end up being a custom built oddity though as I have yet to hear highs as silky as the SDA 1B's in my price range.
Phase 4
What ever amp is suggested for the RTA 11T's I'd like to duplicate it because I have a set of custom made speakers for rears that were practically given to me. The specs and sound is very Polk-ish and were build to be driven by a tube amp from what I've been told.
Phase 5
The final part of this equation will eventually be a Martin Logan Depth as the sub.
Phase 6
Something to pull it all the audio together. No need for video processing.
Home Theater & Listening
RECEIVER Yamaha HTR6180
FRONT AMP McIntosh MC2125
THEATER AMP EMOTIVA XPA 7
FRONT Polk SDA 1B
CENTER Polk CsiA4
SURROUND LR KEF Cresta 30
REAR Polk Monitor 5
SUB Tannoy TS 10 Subwoofer
NAS 20 TB Raid 3 QNAP
Office
AMP Luxman L210
SPEAKERS Tannoy
Post edited by ZaPHoN on
    F1nut Posts: 51,763
    edited April 2013
    CAM??? This is Club Polk.
    I can't think of a good tube amp for $500.00 that will wake up your 1B's. A few suggestions, forget the RTA 11T's and the amp to drive them, take that money and put it towards a tube amp for the SDA's.
    If you want to drive a center channel with a tube amp, it better be a match to the tube amp you drive the SDA's with otherwise the sound will be off.
    Using an AVR as a pre amp for 2 channel is seriously going to hamper the sound quality.
    All that said and IMO, you're better off using your SDA's and tube gear in a separate dedicted 2 channel rig.
  • ZaPHoN
    ZaPHoN Posts: 90
    edited April 2013
    Sorry about the CAM comment. I double posted at CAM too.
    Having a Center and using SDA1B's in a HT is a matter of limited space for the time being. Once a week is my time to listen to the SDA's by themself in two channel only (as sadly lacking as their supply is). It's a matter of compromise. Eventually the Yamaha will be moved to another application or dumped entirely for something dedicated to Audio processing only that can serve as a compromise between HT and listening to the SDA's by themself.
    How about we put price aside and focus on three good used choices for the SDA1B's both in tube options and solid state.
    Any thoughts on a Bel Canto? or other Ice Power alternatives? Maybe "Wired4sound 7 CH (7 x 500w) (MC7x500) - Multi-Channel Amp"
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
  • ZaPHoN
    ZaPHoN Posts: 90
    edited April 2013
    I was thinking of a good used McIntosh MC207 too.
    FRONT Polk SDA 1B
    CENTER Polk CsiA4
    REAR Polk Monitor 5
    Office
    AMP Luxman L210
    SPEAKERS Tannoy
