mono blocking
stuntman3
stuntman3 Posts: 27
edited April 2013 in Electronics
I am interested in two cambridge audio 840w power amps which can run as 2channel and monoblock. I want to use 2 of these 2 drive RTi A9s they reted 200/channel 8ohm -500W mono. I have an AVr with outputs. I need hook up advice for these two Amps
Post edited by stuntman3 on
  • Tankman
    Tankman Posts: 419
    edited April 2013
    Would two Emotiva monoblock UPA-1's do ya? 450 shipped lil over a year old bro.
  • stuntman3
    stuntman3 Posts: 27
    edited April 2013
    Thanks bro. Bt I'm only interested in Cambridge audio and Rotel. Just need hookup advise
  • zingo
    zingo Posts: 11,258
    edited April 2013
    Don't bridge them as you will most likely loose sound quality. Bi-amp them vertically with one amplifier per speaker, using the left and right channels per amp to power the top and bottom sets of the binding posts. This allows you to use a separate power supply per speaker.
  • stuntman3
    stuntman3 Posts: 27
    edited April 2013
    Thanks. Will do bt 1st I have to buy these amps. Is ther a necessity for a sub woofer?
  • zane77
    zane77 Posts: 1,696
    edited April 2013
    The A9's go pretty deep all by themselves if you give them some power
    Two Channel
  • zingo
    zingo Posts: 11,258
    edited April 2013
    I do not prefer a subwoofer with full range speakers that go low enough, but that's just me.
    F1nut Posts: 52,008
    edited April 2013
    You will not need a sub with those speakers.
  • jumpindick
    jumpindick Posts: 428
    edited April 2013
    I don't have sub in the system. The A9s are pretty powerful and have capability to cover low bass. Try without it. See if you like it,
