iPhone / iPad tip
Strong Bad
Strong Bad Posts: 4,278
edited April 2013 in The Clubhouse
This is something I did not know about them. It definitely made a difference on both of my devices. They do seem speedier now. PLEASE, no Apple haters or Android comparisons. This is just a tip to help out the Apple device owners...
"If you experience your iPad or iPhone running a bit slow you probably have a ton of applications running in the background. The device’s memory is limited, so in order to avoid performance issues you can close background applications by following the steps below. Mind you, simply turning the device off and back on will NOT clear the running apps. To close background applications press the Home button twice and when the recently used apps bar appears at the bottom, tap and hold down the app you wish to close.
You will notice that after a second or two of holding down the icon, all the icons in the recently used apps bar will begin to move from side to side. You will also notice that a small red circle with a minus sign will appear on the top-left corner of the icon. Tap the red circle to close the background application. Once you’ve closed all the apps, tap on the Home button again and you will return to the Home Screen. Your device should feel a little snappier."
No excuses!
Post edited by Strong Bad on
  • bobsauto49
    bobsauto49 Posts: 973
    edited April 2013
    I've known of this for a while,and its good advice. Well done!
    "Everything I ever did in my life worthwhile I caught hell for"
  • vmaxer
    vmaxer Posts: 5,120
    edited April 2013
    Strong Bad wrote: »
    Good tip...Thanks
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2013
    Apple will tell you that their method of managing memory is good enough that you don't need to do that, and I agree........when it applies to Apple apps. Not all developers are good at handling memory though. Apple takes most of the issues out of the equation by having a decent API framework toolkit for developers, but people still manage to screw things up with poor coding. I develop for both iOS and Android and since I'm fairly new to Java I much prefer the Objective C framework that Apple uses, but both can be tricky to develop for.
    All that being said, depending on which apps you have installed the trick here can help out some, but I wouldn't even bother killing the Apple apps.
    txcoastal1 Posts: 13,513
    edited April 2013
    The best part of that tip is it helps battery life between charges
  • Sherardp
    Sherardp Posts: 8,038
    edited April 2013
    Do this all the time myself. Good on you for sharing.
  • engtaz
    engtaz Posts: 7,669
    edited April 2013
    I found this out after my phone bricked and apple replaced it. Then the tech informed me of this.
    engtaz
  • Ern Dog
    Ern Dog Posts: 2,237
    edited April 2013
    I tried this in my iphone 3 and instead of red circle on the top corner, I get a black circle with an X in it. When I pressed that it asked if I wanted to delete my app, so I clicked cancel.
  • zingo
    zingo Posts: 11,258
    edited April 2013
    There used to be an app that actually did this without having to do each individually, but Apple remove it from the store. It's still good advice for a little iOS house keeping.
  • AsSiMiLaTeD
    edited April 2013
    Ern Dog wrote: »
    You gotta do it while in the bar on the bottom fo the screen. doublt click the home button, you should get a bar pop up from the bottom with icons, long press on one until you see the red -.
  • Strong Bad
    edited April 2013
    Ern Dog wrote: »
    To close background applications press the Home button twice and when the recently used apps bar appears at the bottom, tap and hold down the app you wish to close. You will notice that after a second or two of holding down the icon, all the icons in the recently used apps bar will begin to move from side to side. You will also notice that a small red circle with a minus sign will appear on the top-left corner of the icon. Tap the red circle to close the background application. Once you’ve closed all the apps, tap on the Home button again and you will return to the Home Screen.
    No excuses!
  • Ern Dog
    edited April 2013
    I press the home button twice and all I see is the same home screen with all the apps. I don't see an apps bar that appears at the bottom. Do you mean the dock?
  • jumpindick
    jumpindick Posts: 428
    edited April 2013
    You, known this for sometimes now. A friend of mine told me. It saves battery life as well.
  • bdaley6509
    bdaley6509 Posts: 1,167
    edited April 2013
    Nice. Did you also know that if your device is off, you can power it on by hitting the 'power' button on the top of the device? And, if you are on an 'iPhone', you can make a 'phone call' by tapping the 'phone' icon.
    Keep the tips coming.
    lol...just messin' with ya.
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited April 2013
    This advice is good advice. It works.
    Another tip that I'm sure many have discovered and used:
    If you use a Bluetooth connection, say to your car's audio system for handsfree operation, you have to turn on the Bluetooth function in your iPhone settings.
    If you do not turn this function off when you are not using Bluetooth, the phone constantly looks for a Bluetooth connection -- thus draining your battery far more rapidly than when the Bluetooth function is turned off.
  • GospelTruth
    GospelTruth Posts: 403
    edited April 2013
    Ern Dog wrote: »
    It won't work on the iPhone 3 as that feature is part of the newer iOS that the iPhone 3 doesn't support. I had an iPhone 3 and was never able to do this however with the iPhone 5 you can.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
  • Strong Bad
    edited April 2013
    Yep, I knew about this one, but good job for posting. I always turn my wifi off as well when not planning to connect with it.
    No excuses!
  • Ern Dog
    edited April 2013
    Thanks. It's time for an upgrade and the iphone 5 is on my list.
