Question about Carver Amp and Integra Receiver
Figured as much.. pretty stupid that they say its coming but its not. Pretty big delivery and one would want to be home. Guess I get to sit around all day again tomorrow.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family!
Do we need to send someone over to remove all sharp objects/weapons from your house, just in case they aren't delivered tomorrow either and you have to wait until Monday?!? :eek: -
Fedex delivers on Saturday.SDA SRS 2.3TL's
SDA 2B TL's -
Have have to pay for Sat delivery. Now tracking says N/A. If that don't change by morning i'm gona have to make some calls. Maybe the trashed the speakers or something. Just don't make sense how it was sitting in there warehouse from 5:30AM and not get put on a truck.
Even if this one shows up tomorrow I still have to sweat out the same ordeal for the other 705 coming next week.Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Oppo 103
Are the gain knobs on the amp turned all the way up? The THX setting on my Carver A-753x is with the gain knobs maxed out.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
The TFM-45 doesnt have gain knobs. Only the amps ending with an X at the end have them (its Carvers designation for THX). So like the TFM-35x, AV-705x, etc."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Well worth a shot. Mine are just little finger knobs on the back. THX probably makes you have them in order to get a THX certification, and then they tell you to max it out. Like you really need the things if your just suppose to max them out.AVR: Onkyo Tx-NR808
Rear: FXI A4
Their purpose was for folks without the ability in their preamp to change levels there to be able to do it channel by channel on the amp."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
