Question about Carver Amp and Integra Receiver
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Figured as much.. pretty stupid that they say its coming but its not. Pretty big delivery and one would want to be home. Guess I get to sit around all day again tomorrow.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • teekay0007
    teekay0007 Posts: 2,289
    edited April 2013
    eclypse wrote: »
    Do we need to send someone over to remove all sharp objects/weapons from your house, just in case they aren't delivered tomorrow either and you have to wait until Monday?!? :eek:
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    edited April 2013
    Fedex delivers on Saturday.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Have have to pay for Sat delivery. Now tracking says N/A. If that don't change by morning i'm gona have to make some calls. Maybe the trashed the speakers or something. Just don't make sense how it was sitting in there warehouse from 5:30AM and not get put on a truck.
    Even if this one shows up tomorrow I still have to sweat out the same ordeal for the other 705 coming next week.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • jbooker82
    jbooker82 Posts: 1,627
    edited April 2013
    Are the gain knobs on the amp turned all the way up? The THX setting on my Carver A-753x is with the gain knobs maxed out.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    EndersShadow Posts: 17,704
    edited April 2013
    jbooker82 wrote: »
    The TFM-45 doesnt have gain knobs. Only the amps ending with an X at the end have them (its Carvers designation for THX). So like the TFM-35x, AV-705x, etc.
  • jbooker82
    edited April 2013
    Well worth a shot. Mine are just little finger knobs on the back. THX probably makes you have them in order to get a THX certification, and then they tell you to max it out. Like you really need the things if your just suppose to max them out.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    edited April 2013
    jbooker82 wrote: »
    Their purpose was for folks without the ability in their preamp to change levels there to be able to do it channel by channel on the amp.
