How to clean inside vintage receiver? Compressed air? Deoxit?
pglbook
pglbook Posts: 2,265
edited April 2013 in Electronics
I need some advice on how to clean inside a vinatge Yamaha CR 2040 receiver that I bought some months ago and am just now getting around to cleaning. The receiver has a scratchy sound when turning volume knob, balance knob etc.
I was advised to use deoxit to clean inside.
However, when I went to a local Radio Shack, the rep told me to use compressed air first.
Is that correct?
Should I spray compressed air in the unit?
If so, where do I spray the compressed air?
Is it ok to spray the compressed air over all of the inside of unit?
Also, when using deoxit, do I just spray it on inside of knobs?
Radio Shack did not have deoxit but the rep told me the Radio Shack lubricant was the same as deoxit.
Is that true?
Thanks. I appreciate it.
Post edited by pglbook on
  • chefkungfu
    chefkungfu Posts: 636
    edited April 2013
    When I clean my electronics, I "loosen" the dust w/compressed air, then carefully use my shop vac to remove the remaining dust. If your really careful you can use a damp q-tip for the hard to reach nook and crannies! Make sure it's rubbing alcohol. I'm not so sure about other methods, this one works most of the time.
    Hope this helps.
    SRT Seismic System with dual PSW1200's
    RT5000 x 2
    RT2000p
    CS400i
    CS350-LS
    LS F/X
    PSW650
    PSW1000 w/Dayton SPA1000
    DSW MicroPro 4000
    Adcom amps
    Pioneer Elite SC-89
    Pioneer PLX-1000 Turntable
    PS4
    XBOX One
    MIT Interconnects
    BJC
  • eclypse
    eclypse Posts: 595
    edited April 2013
    You can use canned air to get it nice and dust free.. but what I've always done to clean electronics is just vacuum it real good as best you can with a soft brush end on the vacuum hose. Carefully as you don't want to break anything inside. Then when your done with that then use the canned air to get into those tuff areas that you could not reach like under the main board.
    Be carefull with the canned air though.. if you accidently shake the can it will spray liquid. If that happends just don't turn it on or plug it in for atleast 24 hours or so to be sure its good and dry.
    The deoxit.. I have no idea what that is so i'll leave that to others. If you need to clean up the knobs then just pull them straight off most likely and see if you can work the lubricant into the post and turn it a few times to work it in there.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
    mhardy6647 Posts: 35,227
    edited April 2013
    1) Cleaning: http://www.audiokarma.org/forums/showthread.php?t=258899
    2) DeOxit: http://www.audiokarma.org/forums/showthread.php?t=207005
    3) comment/tip: one of my own favorite tools for "first responder" cleaning of the really gross specimens is a cheap (disposable-grade) China bristle paint brush (I buy 'em in boxes from Rockler). A couple of smaller camel-hair artist paintbrushes also come in very handy.
    4) If you haven't seen it yet, take a look at this thread to inspire you :-)
    http://www.polkaudio.com/forums/showthread.php?147522-Taking-off-yamaha-box
  • Speedskater
    Speedskater Posts: 495
    edited April 2013
    For the vacuuming part, the is an accessory kit that lets you get into tight areas.
    'Micro Vacuum Attachment Kit'
    http://www.harborfreight.com/8-piece-micro-vacuum-attachment-kit-32994.html
  • dkg999
    dkg999 Posts: 5,647
    edited April 2013
    Car wash.
    DKG999
  • pglbook
    edited April 2013
    Thanks for all of the advice.
    dkg999, should the car wash be a brushless car wash? lol.
    Thanks again. I appreciate it.
    edited April 2013
    This is pretty much what I've done on a few pieces: HK 430, Technics SA-5570, Realistic STA-2270. The Technics was "dust-ball" factory but looks great now. The brush works very nicely! You may want to finish with a little compressed air as well?
    Good luck!
    cnh
  • Speedskater
    edited April 2013
    In the distant past, I was in a repair center of a high end test equipment mfg. They had a commercial dish washer in the back room. They would use it to clean some dirty modules.
    For some time wave-soldered printed circuit boards would get a similar washing.
    SCompRacer Posts: 9,121
    edited April 2013
    When alcohol is involved, I use 99% Isopropyl. A local pharmacy will order it for me if they don't have any in stock. I recently used it to wash a 20+ year old fully vented top cover pre amp board off. I also use it to wash boards I just assembled to get the flux residue off. Canned air helps blow off excess. A hair dryer helps speed up the drying process.
    A project I did after an alky wash.
