Would the LSIM704 be a bad choice to pair with the 705s?
eclypse
eclypse Posts: 595
edited March 2014 in Speakers
I was told by Polk that I should be fine matching the 704 with the 705s and 703s on the sides over the 706 to save some change.
Will I miss anything or regret not just grabbing the 706?
Full 5 channel set of Polk Audio
Fronts - LSiM 705
Center - LSiM 706c
Sides - LSiM 703
Mits WD-82842 82" DLP 3DTV
Denon AVR-3313CI Receiver
Emotiva stealth DC-1
Emotiva XPA-2/Fronts XPA-3 Center-surrounds
Oppo 103
Loving the new Family! :)
Post edited by eclypse on
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Oh man.. what a deal. Wife finally broke down and said whatever so I get to place my order on Monday!
    Sucky part is that i'll have to run these off my Denon 3313CI till I pay off the speakers and make enough for a new amp or 2.
    So in the end it will be like upgrading twice and hearing the speakers all over again for the first time once said and done.
    HAPPY HAPPY!
    Now about that 704?
    My living room is a disaster at 33' long x 13' wide by 18' high cathedral ceilings. Not a closed room with an opening on on side to a hallway that's pretty big and a cut out on the same wall that's a pretty big opening to the kitchen.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • rpf65
    rpf65 Posts: 2,127
    edited April 2013
    I would probably get the 706 of the Polk E-bay site for $960. Good price, and a little better that the 704. At least you won't loose sleep thinking about another if in life.
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Well i'll have to see but i'm paying much less for the 704. $427.47+ tax. Special deal price from an authorized dealer.. Don't ask.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    txcoastal1 Posts: 13,499
    edited April 2013
    I would still recommend the 706, unless you don't have the space or the funds.
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Even with the center and fronts having the same 5 1/4" woofers it would make a difference?
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • eclypse
    eclypse Posts: 595
    edited April 2013
    I'm sure I can swing it just not sure if I can get as good as of a deal on the 706. Other then that I worry about my shelf supporting the extra weight of the 706 at 42.3lbs and the CSi40 I have on there now weighs 24lbs. The standard book shelf plank I have on there stated supporting 20lbs hehe. I guess i'll just figure that out if I go that route.
    Scary having such a large speaker hanging over my 82" DLP on such an angle but its held up so far.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2013
    Yes, get the better 706 and be done with it. I hate buying the lesser and always second guessing my decision.
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Maybe I should just go and grab the 707s while i'm at it since there better then the 705s. lol.. joking! Overkill for my space and so are the 705s but with kids I don't want to risk bookshelf speakers getting knocked over.. not that i'll let anyone close to these!
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
  • leroyjr1
    edited April 2013
    eclypse wrote: »
    Bigger doesn't always mean better. IMO the 705's are a better balanced speaker musically than the 707's, but for a center channel I like the biggest available in that series.
  • eclypse
    eclypse Posts: 595
    edited April 2013
    Right on.. ok well I think it would be best since I have to wait till Monday to place my order that I just wait till like Sunday to bring up the extra 3-400 for the 706 to the wife.. haha was a battle and a half just to get the ok to grab them at this price.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    edited April 2013
    It's easier to ask for forgivness than permission
  • HDTVAV
    HDTVAV Posts: 80
    edited March 2014
    Why would the 705 be "a better balanced speaker musically than the 707"...?
    edited March 2014
    It's about space, if your room is not large enough to accommodate for the sound it will be over powering and won't sound good.
  • HDTVAV
    HDTVAV Posts: 80
    edited March 2014
    txcoastal1 wrote: »
    OK, that is something I have NEVER heard before...
    lol
  • HDTVAV
    HDTVAV Posts: 80
    edited March 2014
    So, in that case - wouldn't the speaker sound "better" at lower volumes...?
    edited March 2014
    Lets answer the question with a question.....why spend the money on a large speaker and play at low volume in a small room. Chosse the right speaker for the space
  • HDTVAV
    HDTVAV Posts: 80
    edited March 2014
    txcoastal1 wrote: »
    If the large speaker at low volume sounds better than the smaller speaker at higher volume...
    Which would you choose?
    lol
    edited March 2014
    In a small/mid size room the smaller speaker.
    My C1 II's are in a 11x12 room although I would like the C4's they would sound like crap in the room at any volume.
    It's about imaging, reflections, bass response etc....it's not about noise.
  • HDTVAV
    HDTVAV Posts: 80
    edited March 2014
    txcoastal1 wrote: »
    Oh, well, yeah, neither the 707, nor the 705 - would sound good in a 11x12 bedroom-sized room...
    I see what you are saying...
    But I would hope that no one would be looking at these speakers with a room that small...?
    edited March 2014
    HDTVAV wrote: »
    Oh, well, yeah, neither the 707, nor the 705 - would sound good in a 11x12 bedroom...
    11x12 room yes, with a bed and other furniture maybe. Will they always be in that room? It's your money, your space your room.
    What I try to accomplish with music and sound in the hobby may differ than what your trying to accomplish.
  • HDTVAV
    HDTVAV Posts: 80
    edited March 2014
    txcoastal1 wrote: »
    Yeah, I agree... I guess I never thought someone would even consider a 707 or 705 with a 11x12 bedroom-sized room...
    I am talking about a 18x24+ foot room with 10 foot ceilings...
    edited March 2014
    If that's the case then I would select the 707's
  • eclypse
    eclypse Posts: 595
    edited March 2014
    Im my new room (12x20) the 705s sound like too much. ;) need to treat the walls for reflextions.
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Oppo 103
    tonyb Posts: 33,065
    edited March 2014
    txcoastal1 wrote: »
    Amen to that....right tool for the right job.
    HDTVAV wrote: »
    lol
    Typically larger speakers need good amounts of current to play well at lower volumes, which usually isn't their strong point. For an amp to put out more current, it needs more drive from the volume control hence why most larger speakers don't sound as good at lower volumes. Amps don't put out their rated power as soon as you turn it on. They only put out what is asked of them at a given volume up to their limits. That said, most amps can produce better current at lower volumes when compared to a receiver. So adding an amp will provide benefits even at lower volumes but the magic really starts to kick in at mid-higher volumes.
    Too big a speaker in a smallish room won't sound as good as a smaller one all things being equal. Big speakers need room to breath, a farther back listening position to appreciate what they offer. Not every home/room is suited for that. So again, right tool for the right job.
