Keebler elves harassed by San Francisco Rec & Parks workers
Danny Tse
Danny Tse Posts: 5,206
edited April 2013 in The Clubhouse
http://blog.sfgate.com/cityinsider/2013/04/04/tiny-tree-door-in-golden-gate-park-must-go-says-rec-and-parks/
It appeared one day in early March: A tiny wood door with tinier hinges and the tiniest doorknob, snugly fit into the base of a tree on the concourse of Golden Gate Park outside the de Young.
The humble home delighted locals, who left little offerings behind the door, including notes in child’s scrawl asking if the tooth fairy is real and if elves can predict the future.
But on Tuesday, the door was gone. The culprit? Rec and Parks workers, who are required to remove anything that’s bolted into the tree.
After brief but intense outcry from door fans, Rec and Parks officials say the door was re-installed Wednesday afternoon.
But it can’t stay.
“Our well-intended and professional staff removed the door, as it is our policy to remove anything bolted to trees,” Rec and Parks spokeswoman Sarah Ballard said in a statement. “As this whimsical addition to Golden Gate Park has captured the public’s imagination, the door will remain up until the elves find a more permanent home.”
That last phrase, officials explained, means the door can’t stay and will be taken down again, though they couldn’t give an estimate as to when.
The door’s bolts damage the tree and hurt its chances of healthy growth in the future, just as would anything else nailed into a public tree. Even cute vandalism is vandalism, apparently.
Let’s hope Rec and Parks has a plan to deal with a family of angry homeless elves.
Post edited by Danny Tse on
  • scottyboy76
    scottyboy76 Posts: 2,905
    edited April 2013
    The bolts do not necessarily hurt the tree.
    In fact bolt and cable is a far preferred method of supporting limbs or newly planted trees because the "cambium", the membrane that brings nutrients and moisture from the roots to the leaves and photosynthesized elements back into the tree via the zylum and phloem capillary like tubing are much more likely to be damaged by tying something around a tree, bolts interrupt a small point in the surface of these structures, much like a needle inserted in your neck, far less likely to cause damage than a string drawn tightly around your neck.
    So there.
    Now, i understand they cant have people just popping anything into public park trees.
    humpty dumpty was pushed
    F1nut Posts: 51,760
    edited April 2013
    Someone here has a serious lack of humor. Do you plan on deleting every post that mentions Kool-Aid?
  • [Deleted User]
    [Deleted User] Posts: 7,658
    edited April 2013
    Give it a break, Jesse.
    Toolfan66 Posts: 18,047
    edited April 2013
  • Drenis
    Drenis Posts: 2,871
    edited April 2013
    Hahahahahaha!!
  • schwarcw
    schwarcw Posts: 7,358
    edited April 2013
    I'm sure somebody has stolen the door by now. Maybe it's for sale on eBay.
    Carl
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited April 2013
    Scottyboy, I'm not sure but were you describing parts of the female anatomy ? Let me know so I can know if I'm offended. :wink:
  • obieone
    obieone Posts: 5,077
    edited April 2013
    Am I the only one impressed by the craftsmanship of that door? Looks like Rosewood.
