Electronic equipment standoff posts?
chiptouz
I want to stack my receiver on top of my amplifier, but I want to add a couple of inches (at most) between the two. I have seen some sort of stand off posts on others but have no idea where to purchase and which ones are better than the others.
If any of you know what I am talking about please respond with some links or at least some names/types that work well.
Thank you,
Chip
Thank you,
Chip
Sharp LC-80uq17u
Denon 4520ci Receiver
OPPO BDP-203 Blu-Ray Disc Player
Monster HTS 3600
Polk RTi-a7 (fronts)
Polk CSi-a6 (Center)
Polk TC-60i (Rear & Surround Rear)
HSU Research VTF3-MK4 (Sub)
Logitech Harmony elite (Remote)
Monster HTS 3600
Post edited by chiptouz on
I have used in the past a couple of pieces of 1x2 painted flat black for this purpose and you really didn't even notice they were there. I have never seen the posts you are looking for.Home Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
hockey pucks!
A little smaller version of the hockey pucks are the black hardened spice jar lids. I have used them for years they blend perfectly cost a buck apiece @ the dollar store and have a hight of 1'' and a 2'' diameter. You also go to Home Depot and just look in the plumbing section and find perfect size fittings of black pvc,which also works for very little cash. The idea here is to repurpose something and not spend alot of $ on a dedicated item.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
For components that have hard drives or CD players or fans, I use 'Sorbothane Hemisphere Bumpers.
http://www.edmundoptics.com/optomechanics/optical-breadboard-components-laboratory-tables/laboratory-tables-breadboards/sorbothane-mounts/1618 -
I use the VibraPods. There was a a more decorative solution, that was brought up by Russman a few years ago, but it looks like their web site is down.
From the WayBack Machine:
http://web.archive.org/web/20110107124653/http://avrisers.com/default.aspx
Since that doesn't help much here are the search results from Audio Advisor:
http://home-audio.audioadvisor.com/search?w=Isolation
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
