Cheap Amp
Early B.
Early B. Posts: 7,900
edited June 2004 in Electronics
Looking for a cheap amp to power my center channel (Csi40). Ran across an AudioSource AMP-100 brand new for around $100. Fits my budget quite nicely right now until I get out of the WAF doghouse for spending money on a 2-channel system. It's 134 watts into 8 ohms bridged. It will only be used for HT.
Do you think it's worth it?
"God grooves with tubes."
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited June 2004
    I picked up a crown D75 last night, if your interested. Run you about a buck and a quarter, but it's a great amp.
    I've got a stack of the A-source, for the money, and for HT, they do what they are supposed to. Good bang-for-buck amps.
    Cheers,
    Russ
