Want to refinish my Polk LSi15s...
jon s
jon s Posts: 905
edited March 2013 in DIY, Mods & Tweaks
I love my Polk LSi15s... Unfortunately, the side panels are finished in that ugly orange-hued cherry. I was thinking of either:
  1. Removing said side panels and stripping it and then refinishing it
  2. Getting a couple of 0.75" MDF panels and completely replacing the said panels.
Questions are:
  1. How easy is it to remove the original side panels. BTW, the LSI15s I got are first generation (later models were slightly different)
  2. How hard is it to strip the original stain and refinishing the original panels? Am I better off just making new panels?
Post edited by jon s on
  • gdb
    gdb Posts: 6,012
    edited March 2013
    Depends on what finish you're desiring I imagine. I think a base-color-clear coat in silver would look cool as $h!t. DIY with some "rattle cans" or have a body shop do it. You could make several sets of panels and change em as your mood changes !
  • Conradicles
    Conradicles Posts: 6,345
    edited March 2013
    I never liked that cherry color either. The lite maple set of LSi9's that a forum member created a while back looked very good.
    F1Nut is a wood guru. PM him and I'm sure he will be happy to help you out.
