energy take 5
joe logston
joe logston Posts: 882
edited March 2002 in Technical/Setup
i have energy take 5 (2) speakers for my effects channels i was wanting to replace them with polk but what polk would be good for that replacement they would have to be small like the energys and have the same tweeter as the cs-400i any suggestions
thanks
. rt-7 mains
rt-20p surounds
cs-400i front center
cs-350 ls rear center
2 energy take 5, efects
2- psw-650 , subs
1- 15" audiosource sub
lets all go to the next ces.
Post edited by joe logston on
  • CHRIS
    CHRIS Posts: 454
    edited March 2002
    Joe-RT25is are the only thing I can come up with unles you go with dipole/bipole.
    Chris :)
  • trubluluc
    trubluluc Posts: 2,067
    edited March 2002
    Joe-
    I also have the yamaha rx-v1.
    The "front effects" speakers put out soooo little info that it's not worth it.
    I bought a pair of rt25i's and had them hooked up for about 2 weeks. The "front effects" signal is pulled off from your front mains,
    but really, it's not even noticable.
    If you decide you must try it, definitely get direct firing, as in, rt series,
    not fx series.
    -luc
  • joe logston
    edited March 2002
    thanks guys i guess i will stay with the take 5s, they are not a bad speaker they look nice to. i kinda wanted to have all polk system but the energy take 5 are a good speaker for the effects channel.
    . rt-7 mains
    rt-20p surounds
    2- psw-650 , subs
