help.trying to hook up a denon avr-2105 7.1 chl reciver to a pma-700v pre amp.
zipzang
zipzang Posts: 1
Can i hook my denon avr-2105 reciver to a pma-700v amp without frying the amp?i would like to use my remote to control the volume from my reciver.is7 this possable?
Post edited by zipzang on
    F1nut Posts: 51,820
    edited March 2013
    It appears that the Denon PMA-700V is an integrated amp, so the answer to your question is no.
  • Habanero Monk
    Habanero Monk Posts: 715
    edited March 2013
    Sorry about F1's response. He is in error.
    You can take the Pre out from your 2105 and go into one of the four audio inputs on your PMA-700V. You will be able to control volume from the 2105's remote.
    Here are some pics
    Welcome to Club Polk.
  • Glen B
    Glen B Posts: 269
    edited March 2013
    zipzang wrote: »
    What benefit do you hope to gain by this daisy-chaining process ? Is there something in the integrated amp that is lacking in the receiver ? Both units are equally matched power-wise, so there is not going to be any noticeable increase in loudness. That takes twice as much power or a 3dB increase. Now, if the amp were at least 200 W.P.C. or more, and you really needed the extra power, the exercise would be worthwhile.
