Show me your ****(embly), and let me get in your guts baby!
1313234363742
  • Moose68Bash
    Moose68Bash Posts: 3,762
    edited September 2012
    I've got an interesting piece of equipment, pictures of which I want to post on this thread as soon as I can dig it out of the closet and take the photos.
    A little tease: Perhaps an iPod precursor?
    More to come later; I hope later today, but maybe tomorrow.
    Cheers!
    Sorry -- it looks like I won't be able to post it till after my trip to Polkfest!
    Family Room, Innuos Statement streamer with Morrow Audios USB cable to DirectStream DAC w/Bridge II; AQ Sky XLRs, McIntosh MC 220 Tube Pre; AQ Sky XLRs, CAT 600.2 Dualmono Amp, Morrow SP7 Speaker Cables, SDA SRS 1.2tls (RD0198s, Dreadnought, Black Hole 5, Acousta-Stuf, Dynamat Extreme, JBWeld. Vr3 Mods: "The Abbot" Monastery-Level Xovers, Custom Internal Wiring, Binding Post Plates, & SDA ICs).
    Exercise Room, Wadia 171 iPod Dock, PS Audio PerfectWave Transport, Innuos Streamer with Cat 6 cable connection to PS Audio PerfectWave MkII DAC w/Bridge II, AQ Sky XLRs, Perreaux PMF3150 Amp, Dreadnought, Supra Rondo 4x2.5 Speaker Cables, SDA 1Cs (Vr3 Mods Xovers).
    Synology 713+ NAS on Gigabit LAN serving PW MkII DAC & DirectStream DAC.
    Clipdat Posts: 9,466
    edited October 2012
    Krell S-300i - Great design!
  • zingo
    zingo Audiophile Posts: 11,255
    edited October 2012
    edited October 2012
    Love the "stealth" wiring around the toroidal. What kind of amp is that?
  • zingo
    edited November 2012
    Clipdat wrote: »
    Balanced Audio Technology 200-VK; 100wpc at 8 ohms, 200wpc at 4 ohms high bias class A/AB (the amp bench tests at about 75% more than the rated power specs :cheesygrin:). The gets a hot as many SS true class A amps I've owned, but it still sounds warm and detailed with much more power and punch. Despite the sparse look in the chassis, because of the transformer and heat-sinks, the amp still weighs about 65lbs.
    SCompRacer Posts: 7,165
    Krell KSL balanced pre amp with Krell MM/MC Phono Board. Primarily Roederstien EK caps and Sprague. I've seen later versions with all Sprague caps. A nice TKD volume control. The first two are Carl's pictures from when it was first sold.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
  • schwarcw
    schwarcw Posts: 7,277
    Hey Rich!
    I see that you have your tools out again! LOL! I took the first two pics, but the last two have your fingerprints on them.
    What a fabulous preamp!
    Carl
    Hey Carl! Just a little bench check, pop the top, clean, run an EKG and check pulse.:cheesygrin:
    Ed is trying to set me up with its old friend, the Krell-der KSA-250. Despite the age it is a very impressive pre amp and phono stage.
  • Gaara
    Gaara Posts: 2,415
    edited December 2012
    Recent purchase -> PeachTree Audio Decco65
  • Face
    Face Posts: 14,340
    Looks like they've beefed up their products a bit. Does this one have balance issues at low volumes like the original Nova?
  • lanchile
    lanchile Posts: 560
    These are the guts of my diy passive integrated amp.
    Make it simple...Make it better!
  • Gaara
    Gaara Posts: 2,415
    Face wrote: »
    Not that I have heard, and I keep the volume between 9 and 11 mostly. I know they changed the amps to IcePower for the new Nova and Grand Integrated, and a chip amp for the Decco, not sure what other changes were made.
    Am looking at the new Nova now for the HT, torn between that and a W4S Mint. If I get it i'll be sure to pop the top and show the guts of that one to, though the only difference should be the amp.
  • Face
    Face Posts: 14,340
    I'm currently using a Mint, it's a nice sounding unit and should be a step above the new Nova.
  • cstmar01
    cstmar01 Posts: 4,393
  • nspindel
    nspindel Posts: 5,343
    Dared MC-7P, stock:
    And after I upgraded the coupling caps:
  • zingo
    cstmar01 wrote: »
    Very nice BAT...
  • cstmar01
    zingo wrote: »
    Very nice BAT...
    Thanks! Not sure what happened to my pictures as it got upside down and I'm missing some.
    cstmar01 wrote: »
    I just flipped the old laptop over....:cheesygrin: Nice BAT Chris!
  • Glen B
    Glen B Posts: 269
    edited March 2013
    Nudies from my equipment collection:
    Class
  • Polkie2009
    Polkie2009 Posts: 3,835
    edited March 2013
    Excellent pics Glen! I actually saw something in the Phase Linear picture that shows an item I have on a Soundcraftsmen amp. Looks like a starburst shaped sleeve that's on the little capacitors??? Are they for cooling? That Outlaw Audio M200 amp looks like it would be sweet for a center channel amp.
    mhardy6647 Posts: 27,151
    edited March 2013
    The things you describe are indeed heat sinks, to dissipate heat. They are usually found on transistors and/or integrated circuits (i.e., active devices) that dissipate some heat, not on capacitors. Some power resistors will have a similar structure, typically built in to them.
  • soundfreak1
    soundfreak1 Posts: 2,888
    edited March 2013
    Marantz 2265B
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Polkie2009
    edited March 2013
    Thanks for the info mrh, I looked closer at Glen's pic of his Phase Linear and the heatsinks are on something that looks more round and flat and not cylindrical like a cap. :wink: I really admire how the Japanese made their electronics so well organized under the hood.:). That Pioneer looks beautiful.
  • Glen B
    Glen B Posts: 269
    edited March 2013
    Polkie2009 wrote: »
    Yes, the starbust shaped sleeves are heatsinks, placed on the driver transistors to dissipate heat. The top Classe picture and the SAE2400 also have ones that are clearly visible. In the Class
  • Glen B
    Glen B Posts: 269
    edited March 2013
    Some more nudies:
    Marantz SR19 receiver w/fan-cooled outputs
    Yamaha C-60 preamp
    Nikko Alpha 2000
    Class
  • ZLTFUL
    ZLTFUL Posts: 5,522
    edited March 2013
    I love me some transformers and the pair in the Omega Omicron... *drool*
  • ZLTFUL
    ZLTFUL Posts: 5,522
    edited March 2013
    Not mine. Audio Research VT200MKII.
    My buddy's shop recently got one in on consignment. I listened to it tonight and am SERIOUSLY considering selling my dirtbike to fund it.
    And yes...that's *8* *pairs* of 6650Cs.
    They had it paired with an Audio Research SP9 MKIII Hybrid tube pre...
  • blairfrischx
    blairfrischx Posts: 256
    edited March 2013
    Just because I love looking inside of it: Stello DA100 Signature DAC
    Face:
    Ycf5vdO.jpg?1
    Inside:
    Some other pictures of inside (link)
    USB Interface: Stello U2, Nuforce uDAC2 ║ DAC: Stello DA100 Signature, Keces DA-151 MK2
    Headamp: Darkvoice 336SE, Bottlehead Crack ║ Headphones: Sennheiser HD650, AKG Q701, Audio-Technica ATH-M50
    Amplifiers: PS Audio 200CX, DIY Class D Monoblocks, Parasound HCA 1200 II ║ Speakers: Dayton RS621, Focal 807V, LSA1 Statement, Soliloquy 5.3
    Power: Yulong P18, Rotel RLC900, Cyberpower 1000VA PFC UPS
  • Glen B
    Glen B Posts: 269
    edited April 2013
    Denon DP-59L
  • Glen B
    Glen B Posts: 269
    edited April 2013
    Audiosource AMP100, 60W x 2/ 150W bridged.
    Audio_100_01_zps03ba5495.jpg:original
    Amp-100_01_zps0c8aeabb.jpg:original
    Amp-100_03_zpsbc1dbcfb.jpg:original
    Amp-100_02_zps5e21ac25.jpg:original
Howdy, Stranger!
