TT feet isolation
Jhayman
I'm sure this question has been asked before somewhere but I'm just wondering do hockey pucks make good isolation pads for TT feet to rest on?
I've seen people that have their TT's on 3" thick cutting boards..
Just wondering.
Just wondering.
Post edited by Jhayman on
These are also a cheap option, but not made for the sole purpose of noise dampening isolation like the vibrapod's.
http://www.rockler.com/product.cfm?page=30951
Or do a pepster and cut racquetballs in half. 2 and your done
. "....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Thanks Keiko..
They look interesting..Not sure about hockey pucks, but these work well and inexpensive.
http://www.amazon.com/Vibrapod-Isolator-Isolation-Feet-Model/dp/B003P4V6WO/ref=sr_1_2?ie=UTF8&qid=1362266612&sr=8-2&keywords=vibrapodsATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
Thanks EndersShadow..
Lol, they look like hockey pucks...lolEndersShadow wrote: »These are also a cheap option, but not made for the sole purpose of noise dampening isolation like the vibrapod's.
.ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
I tried vibrapods and sorbothane balls. Ended up using them both.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A
They have some no slip stuff on top so they are a bit better than hockey pucks :biggrin:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
A real hockey puck is way to stiff for anything that doesn't weight hundreds of pounds.
I often use sorbothane half balls from Edmond. -
These are very inexpensive and can be used for stacking gear (if you must) $13 for 48 of them. Some places charge $24 for four of them.
http://www.pexsupply.com/DiversiTech-MP-2C-Rubber-Cork-Anti-Vibration-Pad-2-x-2-x-7-8Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
Thanks very much Classic Carl
very inexpensive but looks very promising..:biggrin:ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables -
This is what I bought for my TT..
Been using them for 3 days and I find them MUCH better than anything else I have used..
I have them upside down, they are a semi-hard rubber not to hard and not to soft..
I notice a big improvment over the combination feltpad/foam or Hockey Puck I tried or thick felt pads..
$3.99 for 4
Carl, those Pex Supply pads are very nice, but I think that they are designed for heaver machines like air conditioners and washing machines.
I sometimes use these "Hemisphere" Sorbothane Bumpers under components that have hard drives or fans. I haven't tried them under the T.T.
http://www.edmundoptics.com/mechanics/optical-breadboard-components-laboratory-tables/laboratory-tables-breadboards/sorbothane-mounts/1618 -
This is an interesting thread, I'm investigating the same thing. I'm one of those guys who's going to use a cutting board under my turntable. Actually using a 3.5", 3" just didn't seem beefy enough:cheesygrin: I got this one from Amazon:
http://www.amazon.com/gp/product/B00009OWEE/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
I have a new VPI Traveler arriving tomorrow (just sold my Thorens) which stands on it's own isolation cones, I will place the VPI directly on top of the board. But as an extra precaution, I'm thinking about using something under the cutting board for extra isolation from the glass shelf of the audio rack. I'm thinking that using several of the pads from pexsupply would be ideal, and extremely cheap. Any thoughts?Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Actually, for a small amount more, these claim to be even better than the ones with the cork in the middle:
http://www.pexsupply.com/DiversiTech-MP-2E-EVA-Anti-Vibration-Pad-2-x-2-x-7-8Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
You might want to use spike feet on the TT and use the pucks as a base.
The turntable has spiked feet, then they even recommend sitting the turntable on a 2" cutting board. I got the 3.5" cutting board. Set it up last night, first thing I noticed is that the cutting board does not sit perfectly flat on the glass shelf. If I flip the board over it is precisely the same, so I'm quite willing to bet that the glass shelf is a bit uneven, likely because the floor is a bit uneven. So I need something to stabilize the board, right now I'm just using a cardboard shim. I bet the vibrapods would work well here or the squares from pex supply.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Well on my daily quest to find things to do audio wise, I went to Home Depot looking for some thick oak or maple but no luck there as they only have 3/4 inch thick and not in the size I needed.
So I was walking around looking for something heavy and hard and the size I needed for my TT.
I came across the tile and hardwood section I explained to the rep what I was looking for he suggested this tile it's porcelain I said its the right size but I'm not sure how that material is for a TT.
I would have to ask my CP buddies about it before I bought a piece.
So what are your thoughts about this material as a base for TT's??
Anyway he gave me that piece as a free sample as long as I come back and let him know if it worked..I guess he would like to use the info as an added selling point of sorts..
I have suspended on 4 semi hard/ semi soft rubber pads.
I'd still go with wood. Thicker the better. Did you see the Amazon link I put up with the 3.5" cutting board? The thing is a monster.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Speedskater wrote: »Carl, those Pex Supply pads are very nice, but I think that they are designed for heaver machines like air conditioners and washing machines.
They are, but they are the exact same pads that high end audio stores sell for $24 for 4 of them. If you read the description, they are good for up to 50 PSI. The reviews are all from audio enthusiasts who used them for turntables and tube gear.Main System 2.2:
Home Theater 5.2:
I use spikes underneath my cutting boards to level it first. It makes it much easier to level the turntable sitting on it.Main System 2.2:
Home Theater 5.2:
I ordered from PEX Supply. I didn't get the cork ones, though, I got the EVA ones, which are slightly more expensive, but are supposed to be 3X better than cork for absorbing vibrations. I bought them for the board under the turntable, my tube pre, and my sacd player.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
