can I slide the washing machine up the stairs
doggie750
doggie750 Posts: 1,160
edited March 2013 in The Clubhouse
I am working solo. The side of the unit is smooth to slide up the carpeted stairs. Unlike a fridge, this one has no cimoressir so it shoukd be ok. Just worried about misalignment. ...
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • doggie750
    edited March 2013
    Correction: compressor.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • gdb
    gdb Posts: 6,012
    edited March 2013
    Uhhh, duct tape the tub in a centered position so that it can't flop around. Failure to prevent that can cause leaks in the tub/shaft seals. :wink:
  • doggie750
    edited March 2013
    Was gonna do that or wedge it with towels but I figured, it has a room to play like that so the engr should have factored in. Oh well, got a 5yr plan to see this junk last.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
  • Face
    Face Posts: 14,340
    edited March 2013
    Heavy duty hand truck and straps.
    tonyb Posts: 33,072
    edited March 2013
    Wouldn't it be easier to just throw the laundry down the stairs ? :lol:
    Just sayin'
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited March 2013
    tonyb wrote: »
    Wouldn't it be easier to just throw the laundry down the stairs ? :lol: Just sayin'
    Oh ..... that was good. :smile: In fact, that was AWESOME :mrgreen:
  • DaveHo
    DaveHo Posts: 3,583
    edited March 2013
    Go rent a hand truck designed to haul appliances. They will have a track system on the rear designed for going up steps. If your local Home Depot has a rental department, I think I've seen them there.
    http://www.homedepot.com/p/Harper-800-lb-Capacity-Appliance-Hand-Truck-6781/202259411
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited March 2013
    Just slide it up the stairs, like you said. It will be A OK. Way easier to push it up than to pull it up anyways.
    Just dont fall down
    edited March 2013
    I don't know about the stability of what's inside, but as far as getting something like that up a flight of steps let me relate a story.
    A couple of decades ago, my friend was moving into a new apartment and we were trying to get a refrigerator up one flight of steps. So we tried to use an incline and slide it up quite a few steps. We got half way and failed! It was summer and we were drinking like fish, sitting in the middle of the staircase, when the guy downstairs, who had been in the "moving" business, weighed, maybe 145 lbs dripping wet (much lighter and smaller than "any" of us) and his 110 lbs wife got the unit up in a matter of seconds?
    He took a rope and ran it around the bottom of the fridge about 4" in from the back (the front was face up). He then tied each end of that rope around one of his hands (L/R). and had his "tiny" wife balance the fridge on the rope over its bottom while he pulled on it from above with his hands. Once it was "balanced" in mid-air. His wife kept her hands on the bottom (kind of leaning on it with her body) and he pulled it up one step at a time. The several hundred pound piece looked like it weighed almost nothing as he backed his way up the steps without stopping even once!
    And that is how three men whose total weight was almost 700 pounds were embarrassed by a team that weighed less than 260? It also proved that you don't need a bundle of college degrees to come up with a practical solution to a problem. That is something I will "always" remember.
    I'd say get "anybody" on the bottom, and with you at the top--you're up the steps in 30 seconds or less!
    cnh
