can I slide the washing machine up the stairs
doggie750
I am working solo. The side of the unit is smooth to slide up the carpeted stairs. Unlike a fridge, this one has no cimoressir so it shoukd be ok. Just worried about misalignment. ...
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Post edited by doggie750 on
Correction: compressor.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
Uhhh, duct tape the tub in a centered position so that it can't flop around. Failure to prevent that can cause leaks in the tub/shaft seals.
Was gonna do that or wedge it with towels but I figured, it has a room to play like that so the engr should have factored in. Oh well, got a 5yr plan to see this junk last.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Heavy duty hand truck and straps."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Wouldn't it be easier to just throw the laundry down the stairs ?
Just sayin'HT SYSTEM-
lsi 9's -
Just sayin'
Oh ..... that was good.
In fact, that was AWESOME
Sal Palooza -
Go rent a hand truck designed to haul appliances. They will have a track system on the rear designed for going up steps. If your local Home Depot has a rental department, I think I've seen them there.
http://www.homedepot.com/p/Harper-800-lb-Capacity-Appliance-Hand-Truck-6781/202259411 -
Just slide it up the stairs, like you said. It will be A OK. Way easier to push it up than to pull it up anyways.
Just dont fall downOh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
I don't know about the stability of what's inside, but as far as getting something like that up a flight of steps let me relate a story.
A couple of decades ago, my friend was moving into a new apartment and we were trying to get a refrigerator up one flight of steps. So we tried to use an incline and slide it up quite a few steps. We got half way and failed! It was summer and we were drinking like fish, sitting in the middle of the staircase, when the guy downstairs, who had been in the "moving" business, weighed, maybe 145 lbs dripping wet (much lighter and smaller than "any" of us) and his 110 lbs wife got the unit up in a matter of seconds?
He took a rope and ran it around the bottom of the fridge about 4" in from the back (the front was face up). He then tied each end of that rope around one of his hands (L/R). and had his "tiny" wife balance the fridge on the rope over its bottom while he pulled on it from above with his hands. Once it was "balanced" in mid-air. His wife kept her hands on the bottom (kind of leaning on it with her body) and he pulled it up one step at a time. The several hundred pound piece looked like it weighed almost nothing as he backed his way up the steps without stopping even once!
And that is how three men whose total weight was almost 700 pounds were embarrassed by a team that weighed less than 260? It also proved that you don't need a bundle of college degrees to come up with a practical solution to a problem. That is something I will "always" remember.
I'd say get "anybody" on the bottom, and with you at the top--you're up the steps in 30 seconds or less!
