new rack set up
leftwinger57
After getting some grieffrom you guys for pile stacking my gearI finally changes things upw/ a new audio rack I found and repurposed .I added some shelves painted the thing and here we are. If you notice the Yamaha RX-V665
is open w/ all the air it needs the only the speaker selector is on the Adcom. MY Denon dp-11F is on top.The tv is hung as reported before.
Looks better....hope nobody opens that door and smashes the 6 stringer. Try pulling those speaks forward a tad more.HT SYSTEM-
lsi 9's -
Thanks,I have a good 6'' to pull them foward to get it even w/ the console. These are the Time Frame 350s.Now of course after what I been hearing about the vaunted Time Windows once I clear some stuff the hunt will be on ...2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
