Interest Check... Vintage Crossover Plate Shelf for PTP crossovers.
VR3
VR3 Posts: 29,435
edited March 2013 in DIY, Mods & Tweaks
I at this time will not go into much detail but a local fabricator and myself have been working on a "shelf" that will mount to the factory aluminum crossover plate of the bigger SDA models.
This will allow owners to fabricate a point to point crossover or whatever, mount the Gimpod boards on it, etc but allow enough room for the Clarity Cap MR caps if you decide to use them and keep them internal.
I have no idea on price or anything.
If you would have interest in such an animal say so here!
Post edited by VR3 on
  • quadzilla
    quadzilla Posts: 1,543
    edited March 2013
    Dunno... maybe. Been wondering what a ptp crossover wired with litz would sound like.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
    VR3 Posts: 29,435
    edited March 2013
    Talking with the guy... If we could get 9 more folks involved it would be $70.00 plus shipping/paypal...
    The shelf would bolt on to the factory plate and would be powder coated flat black
    pitdogg2 Posts: 27,055
    edited March 2013
    VR3 wrote: »
    The shelf would be powder coated flat black
    With cool red and orange flames:mrgreen:
    just couldn't help myself
    carry on
  • quadzilla
    edited March 2013
    Pricing isn't bad. I'd have to figure out how to mount them in my 2.3s since I don't have a plate. Was looking at a set of 1.2 TLs a few months back, but I'm not sure my room would actually be big enough. The bass from my 2.3s with all the upgrades is already just shy of overwhelming the room, even with my rather modest 45 wpc monoblocks.
    Arm: Rega 300
    Toolfan66 Posts: 18,066
    edited March 2013
    How far in would it go? I would be worried about it affecting air movement within the cabinet.
    VR3 Posts: 29,435
    edited March 2013
    We have discussed putting randomly specific holes in the shelf plus other things - still in the design phase for sure
    VR3 Posts: 29,435
    edited March 2013
    Here is a mock up of the shelf -
    In order to not restrict air flow I thought it made more sense to make a "vertical shelf" meaning all of the components would mount on to what would technically be "the side walls" and there will be a 3" deep floor (cabinet is 10.75" overall depth) that I can mount connectors, etc -
    Based off what I have here this should house a point to point crossover, be compatible with GIMPOD boards if you wanted to unmount the inductor, mount the stock inductor over this plate, reinstall the inductor with the GIMPOD board and remote mount the Clarity Cap MR caps if needed...
    Should be -awesome-
    I have purposely removed the dimensions from the drawing
