Computer guru's...need some mouse help!
starkiller
No, not Mickey...its my cordless mouse. Been lagging really bad when using the wheel to scroll down pages, herky-jerky like. If i use the scroll bar on the right hand side of the page, no problem. Yep, changed the battery..no difference...pc based....thoughts?
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
It's dirty, take it apart and clean it.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Just pop it apart? No screws or anything...Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
No idea I don't wish you too kill it.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Just pick up anew one they're cheapHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
I just picked up a sweet Microsoft wireless mouse on clearance at Office Depot for 10 bucks reg 40, you might look there.
Hmm, so for someone like me who is computer challenged and doesn't know any better, its the mouse and not some kind of computer glitch or software glitch or something? Be a drag to spend the $ and find out the new mouse does the same thing
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
If it's IE that's causing the problem, try this:
Open IE
Press ALT on the keyboard
Click Tools
Click Internet Options
Click Advanced
Hunt down "Use smooth scrolling" and uncheck it.
Monster AVL-300, HTS-2500 MKII -
Syndil
Seems your tip worked, unchecked it and all seems well. But, to me, it doesn't make sense that unchecking it worked since you check the box to engage it...:rolleyes:Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
I have one of those Logitech wireless keyboard & mouse packages. Some of the keyboard special keys stopped working, o I downloaded the newest firmware. Now the special keys work, but the mouse tracking speed restes itself every morning when we turn the PC on.
Speedskater wrote: »I have one of those Logitech wireless keyboard & mouse packages. Some of the keyboard special keys stopped working, o I downloaded the newest firmware. Now the special keys work, but the mouse tracking speed restes itself every morning when we turn the PC on.
Change the settings with you being the administrator. -
starkiller wrote: »Syndil
Glad it worked!
If you had bought a new mouse like everyone else was suggesting, without unchecking that box you'd still have the same problem. :P
