Small DIY USB DAC kits
EndersShadow
EndersShadow Posts: 17,713
edited March 2013 in DIY, Mods & Tweaks
OK, so here's the deal. I have a Audio GD NFB-5 DAC/headphone amp/pre that I am using with a tube amp right now for my 2 channel system.
The NFB's intended use was to be used with the mini-itx computer I build at work so I had a portable hi-fi rig. But I stumbled across something I very much want, a Yarland tube headphone amp.
But in order to use it I would need a DAC as its not a DAC/headphone amp combo like the NFB.
So I am hoping to find a small USB DAC of decent quality that I can find a way to put into my mini-itx computer build. I have a PCI-Express x 16 slot meant for a GPU that I am not using or planning on using so in theory I could use a computer soundcard, but I just think there has to be a decent kit out there that will be better. That and I know soundcards can introduce more noise into the system.
I am hoping to be able to keep the USB DAC all internal to the itx computer so I just have the two items on my desk rather than three. I planned to use a internal USB header so I can use a super short cord, but I am somewhat limited space wise in what I have to work with.
Thoughts/suggestions?
Here are some pics of how much space I have to work with:
Post edited by EndersShadow on
    edited March 2013
    Here are pics from just about 5 mins ago lol
    I might not have enough room the more I look at it, so I might need to start looking at external DAC's lol...
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited March 2013
    Drag**fly might be right up your alley.
  • TNHNDYMAN
    edited March 2013
    what's up with the asterics in the messages? or is it just ** my system where I'm seeing some characters change to asteric after posting
  • blairfrischx
    blairfrischx Posts: 259
    edited March 2013
    Have you considered the ODAC from JDS Labs?
    edited March 2013
    Not really a fan. Had an O2 and it had issues and after having it looked at by a tech determined it would be my last product from him.
    edited March 2013
    TNHNDYMAN wrote: »
    Thought about that, but still not huge fan of 3.5mm to RCA connections. Would prefer straight RCA connectors.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited March 2013
    I'd recommend the Meridian Explorer. I don't share your concern about the 3.5m adapter though, and I'm a cable guy
    edited March 2013
    Will have to look at it then, although the Dragonfly is a little bit smaller and more portable. I REALLY like the concept & simplicity of the Halide DAC but not the price lol....
    I might just have to get the Yarland and deal with a 3.5mm to RCA connection from my computers internal soundcard until I find something....
    My main goal was to find something I could put internal in the computer and not be super expensive. At the price of the dragonfly and explorer I could get a external DAC.
    I have the feeling that might not be possible :redface:.
