Older Amps - ON or OFF?
kevhed72
kevhed72 Posts: 5,163
edited April 2013 in Electronics
I just picked up an integrated and 5 channel Parasound (due my previous 3 channel went bad).
Both the integrated and 5 channel amps around 20 years old. I know this topic was kicked around quite extensively a few years ago hear, but I figured it was worth re-visiting.
What will keep these amps lasting longer (ie before something goes bad with them) - turned ON all the time, or turn OFF when not in use. Lastly, electricity use is not really my main concern. Thanks.....
Post edited by kevhed72 on
    mhardy6647 Posts: 35,238
    edited March 2013
    I don't think this is trivial to answer definitively... I'll offer my opinion; all things being equal, most of the stress on a piece of electronic equipment is the power surge at turn on. Note that incandescent light bulbs usually fail when you switch 'em on, not when burning at steady-state :-)
    The other enemy of electronic components, though, is heat - and at steady state, there is going to be more heat in an idling component than one that's turned off.
    I still think that the turn-on transient is the more damaging of these two "degradation" scenarios :-)
    It is also worth noting that the amps probably do have some transient suppression gizmos in circuit to abrogate the impact of the turn-on inrush (what a rush, man...).
  • adb3da
    adb3da Posts: 507
    edited March 2013
    Bump on this topic because I'd like to hear what others think.
  • Drenis
    Drenis Posts: 2,871
    edited March 2013
    I leave my Adcom 5400 powered on 24/7... I only shut everything down when I'm going to be away from home for an event longer than just a day of work.
  • Tbone289
    Tbone289 Posts: 661
    edited March 2013
    Drenis wrote: »
    ^ This is how I treat my older solid state gear. I power down my tube amp if I'm going to be away from it for a couple of hours or more. There's no point in losing tube life and wasting all that power and heat from a Class A amp.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2013
    I tried keeping mine off but found that it didn't put out any sound.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
    edited March 2013
    ROHfan wrote: »
    You just need a more sensitive pair of loudspeakers.
  • ROHfan
    ROHfan Posts: 1,014
    edited March 2013
    Oh, you mean like Bose? ;)
    edited March 2013
  • chumlie
    chumlie Posts: 8,658
    edited March 2013
    My Parasound stays on 24/7.
  • B Run
    B Run Posts: 1,888
    edited March 2013
    I used to leave my old Adcom 24/7 without ever having an issue.
  • zingo
    zingo Posts: 11,258
    edited March 2013
    I would leave them on unless they are overly warm when at operating temperature. What do they temp after they've been on for an hour?
    pitdogg2 Posts: 27,325
    edited March 2013
    I turn mine off. But i do turn them on for a while before i listen. Hell i don't even leave mine plugged in unless I'm going to listen.
  • kevhed72
    edited March 2013
    zingo wrote: »
    Neither the Parsound or Onkyo are really that warm at all. I was leaning toward leaving them on due the "Dad there is no sound on the TV....." factor alone.:lol:
    edited March 2013
    Almost no good power amps put out much heat when idling. I've had my Adcom on for days, no problem. Heck, it never even gets warm when driving the Lsi-7s. Same with the NAD below.
    But, yeah, don't "do" this with tube amps--things can happen, and "you" might want to be around for "that", just in case!
    cnh
  • sda2mike
    sda2mike Posts: 3,131
    edited March 2013
    my adcom 555 stays on for most of the weekend...dared tube pre, on only when i listen
  • falconcry72
    falconcry72 Posts: 3,580
    edited March 2013
    cnh wrote: »
    ...Almost no good power amps put out much heat when idling...
    .. tell that to my BAT! I'd like to take a temperature measurement at idle. You can't leave your hand on it very long...:biggrin:
    edited March 2013
    cnh wrote: »
    cnh
    well - good Class A power amps put out essentially as much heat at idle as they do at full output power;
    actually, so would bad Class A amps :-)
    Your statement would onl apply to class AB amplifiers (or them digital amp thingies).
  • hochpt21
    hochpt21 Posts: 5,423
    edited March 2013
    I pretty much leave all my gear on all the time. Can't say if it's better or worse...but definitely easier :cheesygrin:
  • BlueFox
    BlueFox Posts: 15,250
    edited March 2013
    On Thursday night I turn on all my two channel, and HT, gear, and leave it on until Sunday night. I have found that both systems sound better after the gear has run 24 hours, and the TV looks better after a day. The rest of the week I turn it on when I get home, and off at bed time. The two channel system especially wastes so much electricity at idle, and the prolonged heat cannot be a good thing.
  • steveinaz
    steveinaz Posts: 19,546
    edited March 2013
    Been turning my amps off for 37 years after every use---haven't had an adverse affect yet. I've owned my parasound now for over 9 years, it gets shut off everytime as well.
  • deronb1
    deronb1 Posts: 5,021
    edited March 2013
    I turn my gear off as well. They are in standby mode though, so in a sense they are still "on".
  • recoveryone
    recoveryone Posts: 929
    edited March 2013
    I use a Integra 2.1 amp in my 2ch setup and it has a standby mode when no signal is detected for 30sec and comes back on when a signal is sent back through. It works great for me as the amp sits behind a piano out of reach, unless I pull the piano out from the wall.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited March 2013
    I always power down in sequence all of the equipment after using it , then unplug it from the wall. Around here, the power has a tendency to go off and on a number of times during the year. Most of my power amps are 20 to 30 years old.
  • michael1947
    michael1947 Posts: 775
    edited March 2013
    I spent a lifetime working for the FAA and everything stayed on all the time, no exceptions. If we has a power outage which was unusual the power up was always frightening. With that said, on 3 of my systems I use a Belkin pf30 which seems to turn everything on and off in sequence which I like. Another thing my in-laws had a house fire caused by one of the first "instant-on" tv's. So to sum it up: I know better but I turn the stuff off.
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
    gudnoyez Posts: 8,174
    edited March 2013
    I just fired up both Adcoms and will shut them down sunday night, instead of turning them on and off when I want to listen to one or the other, as I listen to these the mostly on the weekends and usualy wait a half hour after they have been on to listen, as this is recomended by some of you. neither one gets hot anyways barley warm for that matter even after hours of pushing them. I dont think I would leave any of my stuff on 24/7, I also unplug stuff when not using, as the storms around hear can get pretty intense.
  • gdb
    gdb Posts: 6,012
    edited March 2013
    I turn my stuff OFF, if only to avoid the chance of burning my house down. How important is a longer lasting amp........ compared to a building to house it in ? :wink:
    edited March 2013
    OK, you guys got me. Class A was NOT something I was thinking about, since they are usually "prohibitively" expensive and I highly DOUBT the OP was referring to anything other than AB amps. But you'd think as an academic, "I" would REMEMBER to QUALIFY EVERYTHING I say so that this kind of thing does NOT happen. lol
    OH WAIT! I did "QUALIFY what I said!"
    "Almost no good power amps put out much heat when idling"
    I suppose there is still too much of the old working class boy in my past who likes to chew the fat with the guys without having to ALWAYS remember that he "also" has advanced degrees and regularly discourses with the guys who argue about pinheads and angels! lol
    Then again, it was said of Morris Cohen (the great logical positivist and philosopher of linguistic analysis [what a dead end that was!]) that he had a great memory until his "stroke". After that he was no longer able to harass Paul Tillich who had no real problem responding to him, in any case!
    Carry on!
    cnh
    edited March 2013
    you and I both suffer the curse of being over-educated, cnh ;-P
  • gdb
    gdb Posts: 6,012
    edited March 2013
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited March 2013
    I always turn my parasounds off, as when i turn them on you can here the rather loud slam of the relays kicking in for each channel so the power is directed by them first, so its not going into the system untill they engage. This is to protect from surges ( so i am told ) i also warm then up for about 20/30 min before i pour the juice too them as well.not sure about all parasounds but the 1200 has 4 relays ( i believe ) 2/ch for redundanticy.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
