Next Step
factorz
factorz Posts: 353
edited March 2013 in 2 Channel Audio
I am currently powering my fully modded SDA-1C Studio's with a Denon DRA-397 (80W) and was wondering if moving to something like the Outlaw Audio RR2150 (100W) would be much of a improvement? I know you can use the Denon unit as a preamp so should I just look to go to a separate amp? If that is the case then what is a good unit within the 500-600 range that can give me at least 200W per speaker which is what I read is recommend for the 1C's. Thanks for looking.
Post edited by factorz on
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited February 2013
    IF the Denon has pre-outs so you can use it as a preamp, then your best bang for the dollar is to with an external amp.
    You can stretch your dollar more by going used - and for a solid state amp you can find a good used deal for your budget. Used SS amps are not as risky buying used as a used mechanical audio component.
  • falconcry72
    falconcry72 Posts: 3,580
    factorz wrote: »
    ...what is a good unit within the 500-600 range that can give me at least 200W per speaker which is what I read is recommend for the 1C's....
    Parasound HCA-1500. Do that, enjoy the benefit, then get a dedicated 2-channel pre. :)
  • mjcmt
    mjcmt Posts: 44
    I had the predecessor Denon 395 which has the same amp section as the 397 and thought the sound was very mid-fi. I don't imaginge the preamp section is much better than the amp section. I easily improved on it with something else. The Outlaw gets good reviews, so for the upgrade.
  • factorz
    factorz Posts: 353
    edited March 2013
    Ok so after playing with the placement of my 1C's I am pretty happy with the 397 and have decided that I will keep it in the system for now. So I have decided that my next step should be one of following. Let me know what your thoughts are.
    1. Use the 397 as a preamp and buy a separate amp.
    2. Use the 395 for preamp and amp duties and add a DAC-it. I currently use the internal DAC on the squeezebox.
    3. Upgrade my TT. My vinyl collection keeps growing and I'm currently using a cheap Sony. Most likely move to something like Rega P1 or Pro-ject Carbon.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    edited March 2013
    :idea:Buy a tube amp :cheesygrin:
    SDA SRS 2.3TL's
    SDA 2B TL's
  • factorz
    factorz Posts: 353
    edited March 2013
    What kind of power requirements would I need for the 1C. Most of my choices were in the $400-$600 range and I'm wondering if it's possible to find something tube wise with this kind of budget.
  • michaeljhsda2
    edited March 2013
    factorz wrote: »
    Most definitely. 50 watts of tube power is plenty for the 1C's. The Yaqin MS-20L is rated at 50 wpc and it's a really good bang for the buck integrated. If you buy from Tabnaac in Canada via Ebay it will cost about 615.00 including shipping to your door in about 3 to 4 days. I run my SDA 1C's and SDA SRS 1.2 TL's with it and it sounds great. Plenty of power no doubt.
    SDA SRS 2.3TL's
    SDA 2B TL's
