perfect system for my CD
Systems
I just bought Pioneer DEH-1630 ( 4x45w ) and i need someone to tell me what should i build in my VW mk2 next.
I need to buy:
1) Amplifier
2) Rear speakers
3) Subwoofer ( recommend me enclosure )
I have about 250$,
So what should come first?
P.S.
I have 8" Lamar subwoofer ( 200w ) with no enclosure, but it is souds like Sh..!
I need to buy:
1) Amplifier
2) Rear speakers
I have about 250$,
P.S.
Testing
Testing
Testing
Testing
Testing
$250 for an entire system is not gonna happen.
A good budget system would be this:
Polk Audio DB 6.5 coaxials---$100 (forget rear speakers)
Profile 65x2 amp---$80
JBL GT 12" sub---$100
Profile 300x1 amp---$110
Add about $50 for wiring and another $25 for equipment to build the sub enclosure and thats about $465. Thats about as cheap as I can go with a clear conscience. It aint the best but it will be good, clean and stout sound.polkaudio sound quality competitor since 2005
if you plan on getting an amp later, get some component speakers for the front, then an amp for them, then get a new sub and amp after that
what size speakers do you have front and back?
i don't think the question is for the whole system, it's for "what now". so, what do you currently have? all stock but the HU? id do speakers next, and which ones depends upon what size holes you have in your car.It's not good, very fundamentally simply not good. - geolemon
