What is a safe LFE level?
hamzahsh
hamzahsh Posts: 439
I'm running all my speakers at small setting crossed them at 80hz and bass out to SUB only. I set my Velodyne CHT-15 at 12'o clock position and LFE level in my Yamaha 1400 is set to 0 db.
Now when I watch ROTK the bass is too loud even at 0db LFE level, specially when I crank up to -15db RL. What is the safest LFE level for my sub? I set the level at -5db and seems like it is perfect but am I missing some bass or not. How about -3db would that be safe enough or too loud.
What level setting do you recommend?
Panasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player)
Post edited by hamzahsh on
  • kuntasensei
    kuntasensei Posts: 3,263
    edited June 2004
    No one can really tell you what level is correct, because of the differences in equipment, room acoustics, etc. You need to get a SPL meter and calibrate your subwoofer so that it matches the level of your other speakers.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • HBombToo
    HBombToo Posts: 5,256
    edited June 2004
    I run my h/k at 25% of the max. The h/k is the weak link in my system as far as lfe is concerned.
    1/2Twin
    ***WAREMTAE***
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2004
    I know lot of people keep the level at -3db or -5db. So far I've tried at -5db, I'll try at -3db at -15db RL. The whole reason for asking a safe LFE level is not to bottom out or damage my sub in a long run. Personally I love 0db LFE level but little worried at louder levels sometimes.
    Since I purchased Monter THX Ultra SUB cable. The bass in my Velodyne CHT-15 got louder and tigher and more powerful than ever. The cable did make the difference. :D Highly recommended!
    NAD C272 (2-ch Amp)
  • HBombToo
    edited June 2004
    Cool!
    By keeping the gain in the lfe modest you can push the amp in the 15 with less fear. When the amp starts stressing it will probably be distortion rather than clipping and you'll have a safety cushion to turn it down a bit. When clipping begins its near the end of the game!
    Twin
    ***WAREMTAE***
  • PolkThug
    PolkThug Posts: 7,532
    edited June 2004
    Or, did the sub just break-in? :confused:
    LFE+2 Me like bass.
    Calibration with a dvd is key.
    Regards,
    PolkThug:D
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited June 2004
    Don't confuse the subwoofer level control with the LFE channel trim control.
    The LFE channel trim should always be set at its maximum (i.e., unattenuated) level. This control usually goes from 0 to -10.
    The subwoofer level should be set somewhere in the 25% region (i.e., -5 on a scale of -10 to +10) to keep the signal clean.
    The loudness of the subwoofer with respect to the other channels can only be set with a calibration disc (or by more advanced means like analyzing the atual FR of the system).
    The only "safe" level is one that doesn't wreck the subwoofer; other than that, it's personal preference if you want to run the sub hotter or cooler than the other channels.
    SVS
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2004
    Thanks for the help guys.
    NAD C272 (2-ch Amp)
  • kberg
    kberg Posts: 974
    edited June 2004
    Doc, had a long day, it's getting late, and I'm tired, so forgive the probably stupid question of....what do you mean by LFE channel trim?
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • danger boy
    danger boy Posts: 15,722
    edited June 2004
    what length is the cable? how much did it cost ya?
    PolkFest 2012, who's going>?
  • Dr. Spec
    edited June 2004
    Some of the better pre/pros have the ability to attenuate the LFE (".1") channel on DD and DTS DVDs.
    The LFE channel is normally boosted 10 dB in relation to the surround channels. LFE trim controls typically have a range of 0 to -10. So if you want, you can trim (i.e., attenuate) the amount of boost provided to the LFE channel. So if you set the LFE trim at -5, the LFE channel will only be boosted 5 dB by the pre/pro.
    The LFE trim should always be set at 0, unless your sub is struggling or bottoming on difficult heavy bass passages.
    SVS
  • hamzahsh
    hamzahsh Posts: 439
    edited June 2004
    dangerboy,
    It's 13.3ft and cost me $107 CDN.
    NAD C272 (2-ch Amp)
  • PolkThug
    edited June 2004
    hmmm. Thinking about it now, I guess my Onkyo doesn't have an "LFE" control, just a subwoofer level. So, I actually have SW level +2. (I'll have to go back through the setup and look again, maybe it is there somewhere)
    Regards,
    PT
    VR3 Posts: 29,549
    edited June 2004
    I have mine on 0 -- (dont see how u guys put them on -5)
    volume control on the sub at - 12 oclock
  • faster100
    faster100 Posts: 6,124
    edited June 2004
    its all relative trey, if you dropped your sub plate amp to like 9 or 10 Oclock like mine is, you could bring up the -0 to -5 or so.. give or take... its a balanceing act.. both levels control the outcome
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
    VR3 Posts: 29,549
    edited June 2004
    So basically, you turn down the sub level on the avr -- then you turn up the level on the sub?
    Dosnt make any sense to me...
  • Willow
    Willow Posts: 11,255
    edited June 2004
    I think what it means is set your receiver lowest around 0 and use the sub lfe to adjust...I may be wrong but that how I have mine set
  • kberg
    kberg Posts: 974
    edited June 2004
    Thanks, Doc. No wonder I didn't know about it - I don't have it! :(
    Sub: SVS 20-39 PC+
  • Dr. Spec
    edited June 2004
    With the 20-39PC+, you don't need it, Kev.
    The LFE channel should always be left at the unattenuated setting unless the sub can't take it.
    It's not really a true THX bass limiter per se, but it can accomplish much of the same effect - keep the sub from being overloaded during bass heavy scenes at high volumes.
    It's pretty scary what the standard 10 dB pre/pro boost on the LFE channel can do to a wimpy sub. DVDs are VERY demanding on a subwoofer, particularly considering it needs to handle the redirected bass from ALL channels in addition to the LFE channel if the speakers are set to small. Overall, that's a huge load.
    When viewed in that light, suddenly a dual 12" driver sub packing 1,000 watts continuous doesn't seem much like overkill anymore. :)
    SVS
