What is "level 2 power cleaning"??
muncybob
muncybob Posts: 3,240
edited February 2013 in Electronics
AC line conditioners like to say they have a certain level of power cleaning, level 2, level 4, etc. What the heck are they talking about?
Yep, my name really is Bob.
Post edited by muncybob on
    pitdogg2 Posts: 27,055
    muncybob wrote: »
    Mostly marketing flim/flam IMHO
  • sda2mike
    sda2mike Posts: 3,131
    the amount of pocket-lining profit the sale of each item represents
  • muncybob
    So you would not let it affect your decision between 2 units from the same manufacturer(Pannamax) but one is level 2 and the other level 4?
  • B Run
    B Run Posts: 1,888
    I'd look at the maximum current they can draw and make sure it's enough to cover all of your gear, future gear etc. I think it's a lot of marketing gimmicks but usually there are more benefits than just that to move up to a better model by the same manufacturer.
  • specd_out
    specd_out Posts: 505
    I have monster hts1650 in my ht rig and a panamax M8-AV-PRO in my 2 channel setup. Both have filtration. I dont notice a difference. I look at what they can output what the joule rating is, and if it has an auto disconnect for voltage fluctuations
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
    F1nut Posts: 51,781
    You need to compare what is offered between the different levels to determine what fits your needs, which is pretty much what B Run just said.
    I will add that not all conditioners are created equal even within the same brand. Some are capable of passing high current, some are not. Some have higher joule ratings, which is always a good thing. Most rely on MOV's for surge protection, which degrade every time they are activated, but also simply from time. So, it is important to know what they are using. SurgeX is one company that does not use MOV's, if you want to look at their offerings.
    None of them will protect from a direct hit, so it's always a good idea to unplug your gear in a thunderstorm and also if you are going to be away for a while.
