"clacking" noise at high volumes
Cuchulain
Cuchulain Posts: 66
I've had a new PSW125 for about 2 weeks and its been great. Been listening to music and watching TV until now. Its first big test was today with an action movie and it produced a "clacking" (for lack of a better word) noise on a couple of occasions. It happened on the biggest explosions; so when the most energy was needed. It has continued to work fine since this happened. It was turned up louder than it has been since I got it.
Does this sub just need to be broken in? Specifically, it has happened only with intense LFE signals.
Thanks in advance for any input.
AVR: Integra DTR-50.4
TV: LG 50PS70
DVD/CD/BR: OPPO BDP 93
MAINS: Polk RTiA7
CENTER: Polk CSiA6
Heights: Polk VS 625RT (in wall)
SURROUNDS: Polk TC60i (in ceiling)
REARS: Polk R1
SUB: Polk PSW 125
Post edited by Cuchulain on
  • Cuchulain
    Cuchulain Posts: 66
    edited February 2013
    Noted. Didn't think I had it close to it's limit.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • Face
    Face Posts: 14,340
    Try placing the sub elsewhere in the room. It may be in a null, which will explain why it's not playing loud but exceeding xmax.
  • gdb
    gdb Posts: 6,012
    That "clack" you're hearing is an actual bottoming out of the voice coil. Continued bottoming will alter (mushroom) the coil's shape, then scraping will follow.
  • maxima
    maxima Posts: 143
    If the sub is not place in a corner, you can try corner placement which will greatly increase its output. A possible downside is the bass may sound a bit "boomier".
    Probably a combination of both, volume and placement. Also, that sub isn't ment for a big room either, so if you have it setup in a fairly large room your turning the volume up to try and pressurize the room. Then when the big explosions hit in a movie soundtrack you'll bottom out the sub.
  • Cuchulain
    Cuchulain Posts: 66
    Thanks everyone. I really can't move the sub as I ran the cable behind the wall when I renovated. It's kind of recessed into this window area.
    It definitely benefits from being close to a wall/corner in this spot. I guess it was just a matter of me having a new toy and wanting to see what it could do. The volume was only two thirds up on the sub and set at -20dB on the AVR. The room is about 14' x 16'.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • Face
    Face Posts: 14,340
    Time to pick up a longer cord and experiment with placement.
  • kuntasensei
    kuntasensei Posts: 3,263
    Or go ahead and realize that your room needs more subwoofage than the PSW125 can dish out, return it, and step up to one of the many non-Polk alternatives that will get you that kinda' output on the (relative) cheap (SVS, Hsu, ED, etc.). Just sayin'...
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Msabot1
    Msabot1 Posts: 2,098
    Either a voice coil taxed or source anomalies ! Worked fine except during those passages?
  • Tbone289
    Tbone289 Posts: 661
    Cuchulain wrote: »
    You might benefit from turning the volume down on the sub itself and recalibrating the AVR. You should try to get closer to 0 dB on your AVR. My PSW505 is set at about 1/4 max volume, and that gets me to about -3dB on the AVR, which is close to the same setting as my front and center monitors.
    2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
    Just off the top of my head, I want to say three quarters of volume is way too much. I don't think I ever had a sub where the volume was more than a tad north of half way.
    Is the room enclosed or does it open on one side to another area ? If so, you may need a bigger sub to get some pressure.
  • Cuchulain
    Cuchulain Posts: 66
    Msabot1 wrote: »
    It did. Didn't think of 'source anomalies'; the disc was a dvd rip.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • Cuchulain
    Cuchulain Posts: 66
    Tbone289 wrote: »
    Its turned down now but anything louder than say -10dB is too loud for the room. I don't understand 'recalibrating' the AVR. Do you mean changing my mains back to 'large'.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • Cuchulain
    Cuchulain Posts: 66
    tonyb wrote: »
    Yeah the room is more open. the HT is only part of the room; the room is 25' in total with no door. Theater side is 12x14.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • Msabot1
    I think your equipment and settings are ok....more than likely the source! By the way,think Canada is cool..used to live in B.C.
  • Tbone289
    Tbone289 Posts: 661
    Cuchulain wrote: »
    I mean turn down the volume on the sub, then run YPAO Sound Optimization calibration.
  • Cuchulain
    Cuchulain Posts: 66
    gotcha Tbone, thanks.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • Cuchulain
    Cuchulain Posts: 66
    Done. YPAO set my mains to large which I reversed; set the cross-over to 120Hz which I changed to 80 and set the sub to +3dB which I left. Not sure what the previous sub setting was but with it turned down it has probably changed.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
