Easy way to hook laptop up to Amp or Avr
gudnoyez
Hey since the wife got her Kindle Fire her laptop, sits idle being rarely used. What would be the easiest way to hook it up to one of my Amps or Avr's? what cable would I need, there is a headphone out jack, extra usb ports its a Dell Inspiron 15. I just want to use it to Stream XM radio from laptop out to an auxilary source on a Amp or AVR.
nothing fancy it has whatever soundcard that came with it, plus I have a couple of extra recivers and amps and speakers in storage.
Is this a good idea or should I just forget about it?
Post edited by gudnoyez on
All you neeed is a DAC and USB cable and a budget
http://www.amazon.com/NuForce-uDAC-2-Black-Digital-Converter/dp/B003Y5FRNS/ref=sr_1_5?s=electronics&ie=UTF8&qid=1360514885&sr=1-5&keywords=dac+amplifier2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Easiest way is the headphone jack to an aux/line level input. Cable is commonly available - a 3.5mm stereo plug to two RCA plugs on the other end. It works fine for a simple hookup.
I just use an hdmi cable.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
http://www.amazon.com/RiteAV-Feet-3-5mm-Stereo-Cable/dp/B000V0G2C4
Thanks for the replies guys I just ordered this to get me by and try it out, I like the Dac idea and if it will improve sound quality. I will start saving for one. I was just wondering if there is a Dac out there that draws its power from an outlet and not from your usb on the laptop, and if so can someone recomend one, or is it ok to draw from the usb without worries of burning it up? Thanks again everyone!Home Theater
http://www.crutchfield.com/p_779DAC100B/Cambridge-Audio-DacMagic-100-Black.html
Ok I think this is the one I will be saving my pennies for. I need to just hook this baby up to the laptop via usb, and use the cable I just bought from Dac audio output to the auxillary on my amp or reciever right? I will use the rca jack I just bought for now, but will be getting this one in the future. Hey people I'am going digital:eek:Home Theater
http://www.crutchfield.com/p_1198FTMRCA/Monster-Cable-M-Series-M650I-8-ft.html
Would these interconnects be an insult to that Dac Magic? I like the price and means I could buy a few pairs and leave them hooked up to different sytems and just plug and play to different systems without having to reach behind and unplug every time I want to move to a different System? Heck now I will be thinking about this until it happens when does it end this hobby is addicting for sure!Home Theater
Hmmm. $80 dollar cables with a $70 dollar discount, and the vendor is probably still making a profit. What could ever be wrong here. :rolleyes:Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
From all reports, Cambridge Audio DacMagic 100 is a great DAC and the cable you selected will work fine, but do you really need 8ft of cable for your setup? Additionally, I don't believe the DacMagic 100 has an onboard volume control. I personally like a USB DAC to have that feature.
With Cambridge Audio you would have to move up to the Cambridge Audio Azur DacMagic Plus Digital to Analogue Convert for a substantial increase in cost to gain that feature or try one of the other DAC's that I mentioned.
You mean the volume wouldn't be controlled from the preamp, or the volume control on the integrated amp, or receiver? I don't need 8 feet perhaps the 6 ft audio quest ones would be better same price. Thanks for your input maybe I should then research more into the Dacs that you mentioned.Home Theater
IMO throwing all that money into a DAC just to listen to XM is a waste. Get a USB soundcard with an SPDIF output and use your AVR's DAC, or better yet, use an HDMI cable if your laptop has an HDMI output.
Monster AVL-300, HTS-2500 MKII -
My Gateway is so old it does not have HDMI ports so I used the headphone jack into a mini jack rca female y-splitter >rca cables (my
run is a long one)into audio1 of my Yamaha RX-V665.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
ouch.....my ears hurt just reading that.HT SYSTEM-
lsi 9's -
If it's non-critical listening why not get a USB sound card as suggested above? This sound card has an optical out, but draws power from USB. Not sure if that should be a concern since USB was designed to deliver power. If it still is you could build or buy a power supply or a powered USB hub.
http://www.amazon.com/Creative-Soundblaster-Surround-System-SB1095/dp/B0044DEDCA/ref=sr_1_1?ie=UTF8&qid=1360601321&sr=8-1&keywords=sb1095
HDMI would be another good option if it's available. -
Tony I know it sounds counter intuitive to have that kind of connection but since my computer and avr are in 2 different rooms and
given the limitations of the age of my computer I was limited to options. It does work and most i-net stations come in very strong w/o any side hum or other interference.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
I won't just be streaming XM, now that the DAC comes in play I have a lot of stuff on iTunes and so does the Wife. The RCA cable I ordered should be here in a couple of days. I will try that not expecting much then start saving for a DAC. As always thanks for all the replies.Home Theater
Lots of options from a low end 1/8" to L/R RCAs from the H-phone jack all the way to a "fancy" sound card USB out and a 1000-1500 DAC.
Let's see that's $3.50-$1500+. Obviously sound quality will vary considerably within that range--to state the "obvious"! Depends on how cheap you are. I'm pretty cheap, myself. lol
Have fun!
