Killer deal going down here (ebay)
tophatjohnny
http://www.ebay.com/itm/121061980894?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Where do you think this one will end up??
Post edited by tophatjohnny on
I'm thinking there's going to be a lot of down to the wire bumps.
Dan -
plus it appears to need some repair.... $375-400?Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
$250-300.
That repair is minor and fairly common not a big deal really. When I get a used amp if it has a relay I replace it just to be sure and for the cost of the relay $8 or less why not. Even if it uses 5 of them not sure on that it would still be a easy and cheep repair.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
Better ck that relay price. I replaced the relays in my hca1200 they were 25.00 ea.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Ended:Feb 10, 201313:16:07 PST
Winning bid:US $385.77 [ 32 bids ]MAIN:
Front- LsiM 707 (MIT Terminator 2 Bi-Wire),
Center- lsiM 706,
Surrounds- lsi F/X,
Power sub PSW1000,
Receiver- Harman Kardon Avr 3700,
Amp - Emo XPR-5.
Secondary (2.1):
LsiM 703,
HK Avr 3700,
Yaqin MS-30L,
Polk DSW-PRO 400. -
steve called it. excellent
+1, Excellent call Steve, you pegged it!
I only bid on ebay when I know I'm not competing with more than a "few" others. No use! Bidding wars aren't worth anyone's time! And the final price was OK. Was it a fantastic bargain? No. Reasonable, sure!
