Random Subwoofer Pop
tommyt21
tommyt21 Posts: 685
I have recently noticed that my subwoofer makes a poping noise at random. It happens at all volumes. The sub is plugged into a outlest with our Direct TV power line (not the DTV box). I have tried to see if it occurs when another appliance turns on in the house, however cant seem to find a culprit. I also checked the subwoofer cable and it looked fine. I have it on the auto on, however it makes the poping noise even right after it belted out some LFE. The pop is not super loud but I definetly notice it.
Could it be a bad amp plate?
Or my elites sub out?
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
Post edited by tommyt21 on
  • Anthony Hinton
    Anthony Hinton Posts: 107
    edited January 2013
    Do you have another source you can hook it to?
  • chefkungfu
    chefkungfu Posts: 636
    edited February 2013
    My sub had a similar occurrence (PSW1200). The cables were fine, the woofers were fine, just the amp wouldn't sound normal. It made the popping noise upon signal detection, very weak bass output, then no sound at all. I removed the amp and sent it to Polk CS. When I get it back, I'll post a response regarding the issue, or if was a total loss or not. I believe it's a bad amp plate, could be wrong though!
    SRT Seismic System with dual PSW1200's
    RT5000 x 2
    RT2000p
    CS400i
    CS350-LS
    LS F/X
    PSW650
    PSW1000 w/Dayton SPA1000
    DSW MicroPro 4000
    Adcom amps
    Pioneer Elite SC-89
    Pioneer PLX-1000 Turntable
    PS4
    XBOX One
    MIT Interconnects
    BJC
  • tommyt21
    tommyt21 Posts: 685
    I have isolated this issue to appliances on the same circuit. Both bathroom fans and our furnace.
    Will getting a power conditioner for my subwoofer help this problem?
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • wkjeffers
    wkjeffers Posts: 139
    power conditioners are more for voltage control, not dynamic conditions such as this. I would try replacing switches for the appliances causing the pop when they are activated. The furnace is another issue, if this is the culprit you may have to look into what exactly in the furnace is causing it.
