What center/rears to get?
Yangorang
Yangorang Posts: 2
http://www.polkaudio.com/products/rti12
So I recently got a good deal locally on a pair of Polk RTi12 speakers and I need to complete the rest of the setup. I'd like to stay consistent so I'm mainly considering either the CSi3 or CSi5 for the center and RTi4 or RTi6 for the surrounds. So should I be getting the larger options since the RTi12 is a fairly large speaker or does it not really matter?
I guess I never really understood the difference between the big/small center options such as the CSi3 vs CSi5 and CS10 vs CS20. I notice the bigger option usually offers a few more Hz in the lower frequency response but does it really matter much?
Post edited by Yangorang on
    tonyb Posts: 33,069
    edited February 2013
    Yes, it matters much. Go with the biggest center you can afford and fit into your rack/stand. The center channel does alot of the heavy lifting in a surround system.
  • ViperZ
    ViperZ Posts: 2,046
    Most of the dialogue in the movies goes through the center channel, so the bigger the center channel - the cleaner sound you'll get out of it. A few years ago I upgraded from CS245 to CS400 and the difference was huge.
    Surround speakers don't really matter, as these speakers are mainly used for ambiance sound. It's your choice - you can get RTi bookshelf speakers for more 'directed' sound or 'surround speakers' such as FXi series for more of a surround effect. You don't have to go with the same series or even the same brand of speakers for surrounds.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • rooftop59
    rooftop59 Posts: 8,121
    Welcome to CP!!
    A third vote for the larger center. Not just dialogue comes through that puppy, but any music, special effects, explosions, etc. that the director wants front and center. A while back I started pairing my center with a small 8 inch sub using the sub's speaker-level inputs and outputs, and on bass-heavy tracks like the Dark Knight that little sub pounds. Even with a cs400i (older version of the csi5) the sub still adds a lot.
    But I am surprised that Tony did not mention to you the other option, which is power those 12s well and run sans center or whats referred to as a phantom center. Those 12s could easily handle the front stage on their own especially if given the proper power. I would personally forgo the center and put that 225 (what the csi5 costs direct from polk) into a two channel amp, and then add surrounds and you will have a killer 2 channel and HT setup.
    Good luck and nice score!
    Game Room 5.1.4:
    Bedroom 2.1
  • ViperZ
    ViperZ Posts: 2,046
    I guess to each is his own. Personally, I would never replace a real center channel with whatever 'phantom' effect.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • Yangorang
    Yangorang Posts: 2
    Thanks for the input guys -> I'm gonna go with the CSi5 for the center channel since it just barely fits onto the TV stand and they happen to have it up for sale at the Polk eBay store as well for a pretty reasonable price.
    Still debating on the rear channels. Maybe I can find a F/Xi5 or RTi6 around somewhere.
  • rpf65
    rpf65 Posts: 2,127
    Nothing wrong with using the RTI 4 or 6 for your surrounds. These speakers just trow sound in one direction. Polks FXI series throws the sound in a non-directional area. The difference between the 2 is positioning is more critical for the rti's in this application. Some like the directional option.
  • Csa73
    Csa73 Posts: 36
    Heya i pick the bigger one. As i just upgraded to the CSi5 on wednesday!! What a difference it has made!! Love it wish i found it
    Sooner and for $150 to boot!!
  • larry777
    larry777 Posts: 480
    Yes,the bigger center is better. If you have the budget then go for the FXI, although the RTI series is good also. I use RTi4's for my surrounds and they do a good job. I may upgrade to the bigger FXI series in the future though.
    Home Theatre.............
    Pioneer SC-35
    Polk RTi10's Fronts
    Polk CSiA6 Center
    RTi4 Surrounds
    SVS PB-12 Sub
    2 Channel.............................
    Yaqin MC-100B
    Energy RC-70 Speakers
    Arcam CD-192 Disc Player
    Van Den Hul Interconnects
  • gp4jesus
    gp4jesus Posts: 2,016
    +1 on the larger CC if space allows. Same for matching surrounds
    *all connected w/Premiere ICs
