New-to-me Rotel RB981. Am I missing something?
ROHfan
ROHfan Posts: 1,014
edited February 2013 in 2 Channel Audio
I found an amazing deal on a pair of Rotel RB981s so I picked them up and couldn't wait to get home to give each one a test drive. Having SDAs, I've been looking for something that would power them properly and was resigned to having to wait and save up some dough for a proper amp. I couldn't pass up this deal so I thought maybe I would luck out and these would fill my needs. I have been using my HK3490 as the external amp hooked up from the pre-outs from my Marantz SR5004 and the sound has been heavenly. Sublime, smooth and mellow, slightly laid-back and I looked forward to listening to them every day.
So I swapped out my HK for one of the Rotels and the sound becomes very forward, bordering on harsh. A little fatiguing, in fact. The HK sounded three dimensional, the Rotel sounds two dimensional, like a wall of sound and decreased "SDA effect" (yes, the Rotel is common ground--checked with a meter). I tried the other Rotel and same thing. I begin to get that sick feeling in my gut. There is a noticeable difference in power, low end and punch but I expected--at the very least--similar quality of sound to my HK and was hoping for exceptionally better.
What are the chances of both these amps being bad? Maybe the Marantz doesn't play well with the Rotels? Maybe I need to upgrade to the RDO 194 tweets in the SDA 2As? This is my first forray into separates so perhaps I'm not used to all this power. I would really appreciate some feedback as I'm completely at a loss here. These two amps might have to go on CL.
TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
Post edited by ROHfan on
    If you have the old SL 2000s in there, it is quite possible that you're hearing more revealing details on the top end and it might be time to, yes, upgrade that tweeter, which can sound quite harsh with a lot of very GOOD amps!
    cnh
  • falconcry72
    falconcry72 Posts: 3,580
    cnh wrote: »
    cnh
    maybe..
    OR
    maybe you just like the HK more. That HK is pretty well thought of. I don't have any experience with either piece, but it doesn't appear that the Rotel should necessarily sound any better. Lateral move type thing.
  • nwohlford
    nwohlford Posts: 700
    Just to be sure, you should check that something did not get inadvertently switched when hooking up the amp so that something is out of phase or that left and right are backwards.
    You will want to upgrade the tweeters.
    tonyb Posts: 33,072
    anonymouse wrote: »
    Sorry, but the 981 is not a very powerful amp.
    In a nutshell, yep. Get an amp with some current to make those puppies sing.
  • organ
    organ Posts: 4,969
    A shot in the dark, but there is a chance that the impedance between the receiver's output to the amp's input is not a good match.
    I've had something similar happen to me. I ended up with flat and bright sound with that particular combo.
  • ROHfan
    ROHfan Posts: 1,014
    organ wrote: »
    This is interesting. Flat and bright is exactly how it sounds. I never thought of an impedance mismatch between units but it kind of make sense. Thanks for all the input, gang. I think I'm gonna sell of these two 981s and bank the dough for something much better. I guess this was a classic example of "too good to be true."
  • cfrizz
    cfrizz Posts: 13,415
    ROHfan wrote: »
    Rotel makes great gear, just step up to a more powerful Rotel and you will be fine.
  • RamZet
    RamZet Posts: 792
    That amp is dated. We have piles of them at my office. Look at maybe a Rotel RB1070. 130w x2 and you can bridge it (internal) to get 330w x1.
    Sounds awesome too. Im using one to power a set of B&W CM9s.
    B&W CM9Classé Sigma
    F1nut Posts: 51,820
    You can't use bridged amps with his speakers.
  • RamZet
    RamZet Posts: 792
    Its just an option on the amp. makes the amp good for the future if the user wants to reuse it in another system down the road.
    B&W CM9Classé Sigma
  • ROHfan
    ROHfan Posts: 1,014
    Precisely. Pretty sure I'm done with Rotels for now. Anyone in the NY Metro area can make offers. Maybe I'll get that Emotiva you guys talked me out of in another post :cheesygrin:
