SRS 2.3 vs 2.3 TL
Tekkis
Tekkis Posts: 120
edited February 2013 in Vintage Speakers
I was wondering if there is a big difference between the sound of the 2.3 and the 2.3TL since people talk so highly of the TL version.
System Details:
Marantz SR 5010, Rega RP1, Marantz CD 5004, Denon DRR-680, Carver M-4.0t
Polk SDA 1C (modified), Definitive Technologies BP-10, Polk Audio CS400i
Post edited by Tekkis on
  • schwarcw
    schwarcw Posts: 7,358
    I own the SRS 2.3's and have heard the 2.3 TLs extensively. You will hear differing opinions on this subject. Both sound very good. I prefer the SRS 2.3s, I think they are a little smoother. Mine have had extensive modifications. You can't go wrong either way. It's more a matter of taste and maybe perception. Everything matters. So if you hear the SRS or the TLs in a different room environment, different electronics, source, etc. all of the affect the sound of the speakers. If you were in the market. I would consider the size of your room, proper placement as most important. Just because it's a TL won't make it sound better, that may be a matter of taste as both speakers are only slightly different to my ear. I believe the SRS 2.3a are smoother than their TL equivalent. YMMV. As for the SRS or the TLs I would look for the speaker in the best operating condition, physical appearance and of course price.
    Good luck!
    Carl
  • george daniel
    george daniel Posts: 12,096
    ^^^^ what he said^^^^^ I thought my 2.3's compared to my brother's 2.3 tl's were are tad laid back,,softer,,smoother like Carl said.It's really a matter of taste,gear and room,,everything matters eh? good luck.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    I'd have to hear them both. I had a chance to get a set of 2.3's and decided they were too big for the room I wanted to use them. With a set of 3.1 TL's on the way this week I will at least get a chance to hear what this TL thing is all about. If I were in the market again for the 2.3's, I think I'd hold out for the TL's! That said, I still love every SDA I've had my ears on!
  • drumminman
    drumminman Posts: 3,396
    schwarcw wrote: »
    Good luck!
    It's a problematic comparison unless both speakers have the same mods, are driven with the same front end, and listened to in the same room.
  • civilian
    civilian Posts: 357
    Even the speaker placement in the room will make a difference. The age of these speakers means that even if 2 pairs "roiled ff the line" together they can have vastly different hours of usage, the pasture swings etc.
    ________________
    2 Channel-Denon AVR-4520/SDA 2.3TL's
    5.1-Denon AVR-4500h/RT3000P's/CS1000P/RT2000P's/
