Which amp for Tyler Acoustics Linbrook?
Ern Dog
Ern Dog Posts: 2,237
edited April 2014 in 2 Channel Audio
Well my current gain-clone chip amp isn't compatible with my new Linbrook Signature system speakers, 2-piece. So, I'm now in the market for a new 2 channel solid-state amp. I have $1000 to spend on a used amp. Not sure what would be a good match. I'm looking for a nuetral sounding amp. Here are some amps I'm thinking about:
Parasound Halo A21
Belles 150A
Rotel 1080
Emotiva XPA-2
Post edited by Ern Dog on
  • Ricardo
    Ricardo Posts: 10,636
    edited March 2009
    The Belles will do a good job if you're talking aboit the Reference.
    A couple more options:
    -Marsh A400s
    -Any decent tube amp 60 WPC or more.
    The linbrooks are relatively efficient (92db and 8 ohm IIRC), so you do not need a lot of power to drive them.
    SOPA
    treitz3 Posts: 19,991
    edited March 2009
    If you can squeeze out a little more...........
    http://www.polkaudio.com/forums/showthread.php?t=79103
    Then be ready to whack pud for sound.
  • hoosier21
    hoosier21 Posts: 4,418
    edited March 2009
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • phipiper10
    phipiper10 Posts: 961
    edited March 2009
    I think the Parasound and Tylers will make a VERY revealing combo. I had this combo previously with the Anthem pre 2L in the middle. Some recordings were TOO revealing. Not all but some enjoyment on some discs was lost as I started to over analyze mixes and everything the engineers had done. It probably depends on what you listen too and your room acoustics. It may be what you want. I also had a Rotel though it was RB990 BX. Similar thought to the Parasound however I think the Parasound was cleaner/more refined.
    I since went the opposite direction with the BlueCircle amp but it was too rich. I Took a small step closer to neutral with the B&K.
    No Belles experience. Not even gonna say the "E" word. Good luck.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • I-SIG
    I-SIG Posts: 2,243
    edited March 2009
    Don't know the seller but the amp is killer.
    Wes
    http://www.polkaudio.com/forums/showthread.php?t=79733
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • jm1
    jm1 Posts: 618
    edited March 2009
    It will also be interesting to hear what you think of the Dynaudio's once you get a good SS amp. I'm using Simaudio for my Danes. You might be quite surprised.
    All truth passes through three stages. First, it is ridiculed, second it is violently opposed and third, it is accepted as self evident.
    Arthur Schopenhauer
  • Ern Dog
    edited March 2009
    Thanks for the suggestions. Lots of good ideas. So far I'm leaning toward the Cary CAD-200, Parasound Halo A23 (instead of A21) or Vincent SP-331 Hybrid. Not much info about the Vincent, but it did win TAS Best tube amp award under $1k. The Parasound also is highly regarded. And I know Cary is rock solid, just a bit more than I have to spend. I'm gonna do more research and pull the trigger on one of these very soon. And what ever I get I'll definetly hear how my Dynaudios sound with the new amp. I can't do the shoot out until I get an amp for the Linbrooks.
  • phipiper10
    edited March 2009
    Almost as good as waiting for the next phish show!! That's it ... Have a live feed of the shoot out playing phish tunes!
    I'll pay for audio admission :)
  • george daniel
    george daniel Posts: 12,096
    edited March 2009
    I'm running my 7u's with quicksilver M-80 mono's and the taylos with VTL compact 100's monoblocs. Good luck:)
  • Ern Dog
    edited February 2013
    Here I am 4 years later from when I started this post and I still have the same speakers and still love'em. Amps I've tried on these speakers are Rogue Audio Stereo 90, Pass x150, pass x150.5 and now currently with pass xa30.5. I've also switched to an all digital source with my Macbook pro and overdrive dac. My rig sounds very resolving and neutral, but it's missing something. I was at a friends house and was blown away with how good his tube mono blocks sounded. And so I'm thinking of trading out my Pass amp for some tube mono blocks.
    I've taken out my Placette preamp and I'm going direct to my amp from the dac using XLR's. So the tube amp needs to have xlr inputs and needs to have at least 100+ wpc. My speakers are 90db 4 ohm. I also don't like overly romantic sounding tubes, not syrupy, and no bloat. It has to be fairly neutral and not emphasize any particular frequencies- flat, with a dash of warmth. I'm hoping for a full sound, texture and 3 dimensional.
    So far on the top of my list is a used Atma-Sphere MA-1 mono blocks, which are 135 wpc into 4 ohms. I wish I could get away with the M-60 model but it's only 45 wpc and I don't think I would get the bass impact I need to power the four 8" bass drivers. Any other suggestions?
    Thanks,
    Ernie
  • Face
    Face Posts: 14,340
    Why not a tube pre instead?
  • cstmar01
    cstmar01 Posts: 4,424
    Bat tube monos come to mind. Or vtl. My vtl are not overly fat, and have an almost ss sound yet still some good tube sound.
  • Ern Dog
    I don't need a pre amp. I prefer to go direct because it simplifies the path and sounds more transparent.
    I used to have a Modwright 9.0 SE tube preamp and replaced it with the Placette active preamp because it was more transparent.
  • organ
    organ Posts: 4,969
    Hi Ernie,
    Long time no see. What's the min imp dip of your Tyler's? As long as they are efficient/sensitive enough, there is no need to worry about what size woofer you're powering. Using Klipsch La Scala for example. They have 15" woofers but can get away with incredible impact and power with less than one watt due to their sensitive nature.
    You said your speaks are 90db and 4 Ohms. The 4 Ohms is going to be a challenge already but 90db is quite efficient. So you'd want to focus on a tube amp with a good beefy power supply. Just like SS, not all tube watts are created equal. If they dip below 4 ohms and/or have wild impedance swings, you're much better off with SS, IMO. Also, the 4 ohm output taps on most tube amps don't sound as good as the 8 ohms. Most output transformers in tube amps are optimized for the 8 ohm taps. If 4 is your speaks min, you should be able to get away using the 8 ohm taps.
    Why don't you bring your speakers over to your friend's house and listen to them with his amp to see how work out with tubes. Or if he doesn't mind, maybe he could bring his amps over to your place. If possible, it's a better option because it's in your listening environment.
  • Face
    Face Posts: 14,340
    I agree with cstmar01 and would lean towards BAT also. Manley should be another consideration also as I didn't find their amps overly lush or "fat" either.
  • Ern Dog
    I had the same idea of having my friend bring over his monos. They are Audion Black Shadow 845 monos which deliver 25 wpc class A. He's coming over next weekend. It will be a fun comparison seeing how it sounds vs. Pass 30 wpc of class A. I'll post my thoughts about it.
    In the mean time I'll do some research on BAT & VTL.
  • Face
    Face Posts: 14,340
    I would also check out Ayon.
  • organ
    organ Posts: 4,969
    Sounds good. Let us know how it goes.
  • gaspipe
    gaspipe Posts: 13
    Blowing the dust off this thread....
    I've had my Linbrook Signatures for a year or so now. At first, I was planning to flip them because I got them fairly inexpensively because they had a crossover issue. I fixed that, and fell in love with the damned things. I'm powering them with a pair of modded driver board Hafler XL280's in mono, with a Musical Concepts Chameleon preamp with a Telefunken 6922 tube.
    I guess they are keepers. Hope you like yours as much as I love mine!
    gaspipe - the original
    Cambridge 740c, Musical Concepts Chameleon, 2x Hafler XL280, Tyler Linbrook Sig's
    NAD C545BEE, Vincent SA31, ADC315X, Hafler DH500, Polk LSi9, PSW650
    I damn sure do know I love mine. Didn't at first and actually thought I had made a mistake but once I got the synergy thing going? In a word. Whoa. Planning on an external x-over upgrade within days. My profile will spill the beans on what gear is associated.
    Congrat's gaspipe on one fine purchase. I'm listening to them right now and even after all of these years, the goose bumps still visit often.
  • Ern Dog
    Treitz3- I'd also like to do the crossover upgrade for mine too. It's on my list. I hope you post your impressions because I'd be interested in hearing about your impressions. Although, everyone that get's this done seems to really like the results.
    Lately I've been lusting after the Audio Research Reference 150 tube amp. It is more than I can afford, so I might have get the VS115 instead. We'll see what I end up with.
  • Obsession18
    Obsession18 Posts: 191
    I've had my 1-piece Linbrook Signatures for about two years now, I bought them as trade-ins from Ty for what I now realize was a friggin killer price. I've been really happy with them - then I went analog and added a turntable, it brought tears to my eyes.
    2-Channel System
    Analog: VPI Traveler TT, Audio Technica 150MLX, Pro-Ject Tube Box DS
    CD Player: Jolida JD-100 Preamp: Cambridge 840E Amp: Odyssey Kismet Stereo
    Spkrs: Tyler Acoustics Linbrook Signature Systems
    tonyb Posts: 33,072
    Ern Dog wrote: »
    Thanks,
    Ernie
    Good choice Ern, maybe talk to Ted, I think he still cries like a baby with those Wolcotts. Audio Note is another to look into as well as VAC. Incidently, given your dac, have you tried the offramp with it ? Those who use one simply love what it does.
    Not so sure I'd worry about 45 watts and 4 8 inch drivers. Bigger drivers, maybe, 8 inchers...nah.
  • Ern Dog
    I've heard that the bass is kinda thin with the Atmas and that's not a good thing for me. The arc supposedly has way better bass.
  • george daniel
    Big A$$ VTL mono's will do the trick.
  • gaspipe
    gaspipe Posts: 13
    treitz3 wrote: »
    When I was working through my XO issues, I changed some pm's with Trey. I still want to upgrade the XO's in mine too. It's hard to imagine better sound until you have it. :D
    Hello, Ern Dog. You betcha' I'll be posting my impressions! My final observations won't be made public for a "guestimated" two months, though. The speakers will be leaving the rig today and we are estimating a month at worst to have the external x-overs done, wired up and installed into the boxes they will be going into. The speakers will be recorded in the studio before the upgrades, after the upgrades and then once again, after break in so you can "sample" the differences yourself. I'll start my observations [good or bad] when the upgrades are done but will reserve my final observations after about a month of listening and break in.
    Hey, gaspipe. I have heard the changes the same x-over upgrades I am planning for the Signatures on Trey's Tyler Acoustics Super Towers. Believe it or not, the difference was flat out amazing. It took a really good performer and catapulted them into a superb performer. After his were broken in, it was somewhat hard to come home and listen to mine after listening to his. If the sonic end result is as good with mine as it was with his, I'm fairly confident that I will take these speakers to the grave with me. That's a far cry from my initial observations with these speakers.....thinking that I had made a "mistake".
  • Ern Dog
    treitz3 wrote: »
    Cool. A worthy investment for sure.
  • Ern Dog
    So I had an opportunity to listen to Audion Black Shadow mono blocks which use the 845 tube. They are SET amps with 25 wpc. They totally outclassed my XA30.5 and I would hope so at $14,000!
    I've never heard the Tylers sound this good before. The black shadows basically did everything better except in one area. First off, instruments sounded more realistic. There was more resolution, depth, more separation between the different instruments, and so on....
    The only place they started to run out of gas was when I listened to the Gladiator soundtrack, "The Might of Rome," which is a very powerful classical music piece.
    They look friggin gorgeous to boot.
  • Ern Dog
    Well I decided to pull the trigger on tube mono blocks, Coincident Dragons MK I. They are 75 wpc. I found a used pair on audiogon that should arrive next week. More to come...
