Crossover question
Cuchulain
Cuchulain Posts: 66
If a sub woofer has a range of 32-225Hhz and the crossover is 60-110Hz how will it ever play above 110? If its set at 110 doesn't that mean it plays only 110 and below? I apologize for my nievity.
AVR: Integra DTR-50.4
TV: LG 50PS70
DVD/CD/BR: OPPO BDP 93
MAINS: Polk RTiA7
CENTER: Polk CSiA6
Heights: Polk VS 625RT (in wall)
SURROUNDS: Polk TC60i (in ceiling)
REARS: Polk R1
SUB: Polk PSW 125
Post edited by Cuchulain on
  • Cuchulain
    Cuchulain Posts: 66
    edited February 2013
    I think I got it. Thanks ZLTFUL.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
  • kuntasensei
    kuntasensei Posts: 3,263
    Plus, if the subwoofer has an unfiltered input (sometimes called LFE input), that bypasses the analog crossover on the sub. Most digital systems don't require a crossover on the subwoofer itself, since your receiver is handling all the system crossovers and combining the redirected bass with the LFE channel for a single output to the subwoofer.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • wkjeffers
    wkjeffers Posts: 139
    nice graphics, my engineering brain is pleased that you provided that! great.
    tonyb Posts: 33,066
    Cuchulain wrote: »
    What subwoofer do you even want to play above 110 ? Most subs are used for mid to lowbass frequencies below that point, not above. Since you have the A7's, you don't want to set it that high anyway. Your problem as I see it anyway is your sub isn't going to do much better than the 7's except in the lower regions. Upgrade that sub for substantial improvement.
  • Cuchulain
    Cuchulain Posts: 66
    I just used the values of the 125 to ask the question. I don't necessarily want to play it above 110Hz. And I just upgraded to this sub, its less than a week old.
    TV: LG 50PS70
    MAINS: Polk RTiA7
    CENTER: Polk CSiA6
    REARS: Polk R1
    SUB: Polk PSW 125
