Wanted CS400 Center Speaker
jasonp
I'm looking for a good condition CS400. Thanks.
Post edited by jasonp on
check your pmLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
forum says not enough posts yet to send or view PM's
Jasonp, where are you located?
I have an extra CS-400 in excellent shape, but I will not ship. -
I have a cs400i which is basically the same in pretty good shape overall and I will ship it for 125 if the deal with Dave falls through.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Dave,
I'm in the Boston area so that doesn't work if you're in TX but thanks anyway. Rooftop, the cs400i sounds good but let me do some measuring tonight. I thought the cabinet height was under 8 1/2" but now I see it's 8 5/8". It's tight so I just want to make sure it fits before I commit. -
rooftop, my apologies. I don't have enough clearance for the cs400i - I got all excited after someone recommended it and the reviews are great but should have measured first. Have to turn my attention to the cs350ls/cs225/cs245 now, which unfortunately, don't seem to be in the same class as the cs400. Sorry for any
Find a CS-350 and you will not be dissapointed. I have two 400i's and a 350 and they are all steller with very very similar tonal qualities.
i cant wait to find a lsic to replace my cs400..
Rooftop: I could lift the CS400i off your hands if you're still willing to let it go for $125 shipped. I'm in Amherst, Massachusetts. Let me know if the item is still available.
