Fixing crack in rtia9 cabinet ?
milkdudski
milkdudski Posts: 2
edited January 2013 in DIY, Mods & Tweaks
I bought an rtia9 on ebay with so called minor cosmetic damage. Surprise!, the speaker has a six inch crack on the cherry side cabinet, top left side -horizontal and three inches from the top, so its highly visible.:sad: I can see the unstained wood so tranlation has occured due to impact. How do I fix it? Do I even bother to fix it? Will it eventually spread throughout the whole side cabinet if not dealt with immediately? Thanks
Post edited by milkdudski on
    treitz3 Posts: 20,084
    edited January 2013
    Welcome to the forum, milkdudski. My best advice would be to return the speakers. From what you describe, that's not minor cosmetic damage. Sounds more like major structural damage and if that's the case, there's no telling what else may have been damaged internally.
  • milkdudski
    milkdudski Posts: 2
    edited January 2013
    Thanks tretz3. I would return it but I got it so cheap. I want to fix it if possible instead of driving it back to seller over 125 miles away. I had a friend pick it up and shipping it would be too costly.
  • seabeerob213
    seabeerob213 Posts: 1,843
    edited January 2013
    find a broken one with a good cabinet and part out the two into one usable one,
    edited January 2013
    If that is the case, I would suggest posting a couple of pictures so that we can see what we are looking at here.
  • Pastorfuzz
    Pastorfuzz Posts: 24
    edited January 2013
    If the crack is all the way thru the wood, drill a hole at each end of the crack(this will prevent the crack from spreading). Use a bit
    slightly larger than the crack itself. Then use a Dremel tool to grind into the crack about 3/4 of the way.
    Clean, then use quality wood filler and stain. Ive done this to a Monitor 70 2 years ago and it's still holding.
