sqb touch ethernet connection
sda2mike
sda2mike Posts: 3,131
edited January 2013 in Going Digital
when i had a classic in my main set up, i used the ethernet conn so the dvd player could go wireless...no joy with the touch...is there a set up procedure i'm missing? i'm using all outs on the sqb...coax to my dac, stereo to avr and ethernet to dvd
thanks
mike
Post edited by sda2mike on
    edited January 2013
    Not following as to why you need to use all the outputs. Wouldn't just a digital coax output work for going into a dac ? Then analog out to the receiver ? Why go into a DVD player at all ?
  • sda2mike
    edited January 2013
    tony
    so the dvd player can be on my network...i use the sqb as a hub...
  • zingo
    zingo Posts: 11,258
    edited January 2013
    The SBT does not have a network output (as far as I know) if that's what you're asking; just the wireless or wired connection. You will need a network source to feed both your DVD player and SBT, whether that's a wireless router or wired switched.
  • sda2mike
    edited January 2013
    hmmm. it worked with the classic???
  • dragon1952
    dragon1952 Posts: 4,907
    edited January 2013
    zingo is correct....that's an input only.
  • zane77
    zane77 Posts: 1,696
    edited January 2013
    You can pick up a 4 or 8 port switch really cheap
    Two Channel
  • sda2mike
    edited January 2013
    i'll google the port switch idea...at the least, i can use my classic for the dvd player..like i said, it worked as a hub..
