I need to find a high quality/reliable win 7 laptop
WagnerRC
I am open to all suggestions. Quality is the key here. And I could also use a recommendation on a high quality multi usb port minimum of 14 ports. Quality and reliability is the key here too. All i can find is cheap usb ports.
Thank you
Thank you
Post edited by WagnerRC on
sorry a usb hub. My friends in Italy use a brand in Italy that I cant find here. They use MATSUYAMA USB hub. I do a lot of reprogramming of a usb device.
Right now I use a satechi 12 hub and its not very reliable
Check out http://dx.com .
Monster AVL-300, HTS-2500 MKII -
Thank you
Leveno, Dell XP model, or Asus would be my vote. For USB I would say Elecom
http://www2.elecom.co.jp/cable/usb-hub/u2h-z10s/index.aspShoot the jumper.....................BALLIN.............!!!!!
I'd suggest staying away from Hewlett Packard, forever.
bought a lenovo x 230 thanks
I ordered the monoprice hubs too. Right now I am using satechi that look just like the elecom and they are a pita
