Going "Old School" with a CAL Alpha DAC...
pearsall001
I just had to do it, snagged it for a great price so I figured why not. This will be a fun comparison to my current CA DacMagic, which I like alot! The Alpha DAC is coming with Amperex 12aX7 (2) tubes (hint, hint...any tube rolling recommendations). From what I've read this DAC is no slouch even though it's dated, buy mated with the right tubes it can rival a lot that's out there today. Truth or fiction? We'll find out shortly.
Post edited by pearsall001 on
I don't have experience with that particular DAC, but, as with any DAC, the quality of the analog section is critical to good sound. Point being, an older DAC with an excellent analog section will sound better than a new DAC with the latest chip but a crappy analog section. I have a 15 year old Parasound DAC-2000 Ultra that will dominate almost any new DAC. The only DAC's that sound better than that old Parasound are newer ones with newer chips whose analog sections are on par with it.
Congrats, looking forward to your impressions! I think you're in for a treat...2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
You can find comments like smooth and rich, best DAC ever; or the tube output stage is sub par compared to the SS gain stages before it making it sound veiled. Do you know which version/year it was made?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
SCompRacer wrote: »You can find comments like smooth and rich, best DAC ever; or the tube output stage is sub par compared to the SS gain stages before it making it sound veiled. Do you know which version/year it was made?
It's the original 18 bit version not the 24/96. If I find it necessary it can still be upgraded to the 24/96 version. But from what I''ve read the original 18 bit version is where it's at. Time will tell."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Sweet Dac.....Congrats!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Ahhh yes the Crystal CS4328,one of the first good sounding Delta-Sigma dac chips.I still have one in my parts bin from my first DIY atempt at a stand alone dac.
double post
Cool Phil, I would imagine a pretty good analog sound from that dac. Let us know your thoughts.HT SYSTEM-
lsi 9's -
Tony, let's hope so. The CAL Alpha DAC I believe is the polar opposite of the DacMagic (which I really like). This will definitely be a nice comparison. I'm surprised no one has chimed in yet with some 12ax7 tube recommendations. It's coming loaded with Amperex tubes which I believe are pretty darn good to start off with."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Depends on which Amperex they are, and by that I mean year and plate type, getter etc. Search some of my old tube threads, lots of 12AX7, 5751 info.
Sylvania 3 mica black plate GB 5751 are among my favorites, not cheap however.
....Delta-Sigma......
I was in that fraternity; they had us under double secret probation.:cheesygrin:
CS4328, SOTA in the mid '90's, eh?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Not quite,the multi bit chips like the PCM63 and AD1862 could piss further but the 4328 got high marks for musicality and was very easy to work with making it nice for DIYing.It was a highly integrated with on board output buffers so could be used without any additional out stage if one chose the simplest route.SCompRacer wrote: »CS4328, SOTA in the mid '90's, eh? -
When the unit arrives I'll get the info from the tubes & try to track down their origin. I read up on those Sylvania's you mentioned...very sought after. Hmmmm."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
The DAC should be hear on Friday...looks like it'll be a fun weekend."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
How is the Alpha treating you?
I have a Sigma II on the way.Speakers: SDA-1C (most all the goodies)
What is tube rolling?ATC SCM40's,VTL TL 2.5 Preamp,PSB Stratus Goldi's,McCormack DNA 500,McCormack MAP-1 Preamp,Pro-Ject Xtension 10 TT,Ortofon Cadenza Red/Nordost RedDawn LS Speaker cables, Bryston BDP-2, Bryston BDA-2,PS Audio AC-3 power cables
I couldn't be more pleased. It conveys a very smooth, natural sound that literally draws you in. I'm sure the Bugle Boy tubes have a lot to do with it. You have to let us know how you like the Sigma II. CAL made great stuff back in the day. It's a shame when they got bought out all that seemed to stop."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
