DIY cables - where do you buy bulk cable?
ambiophonics
The title sums it up pretty well. I'm looking at making some custom cables, mostly RCA, for my rig and would like some input on where you guys buy your bulk cable, connectors, etc. Any input is appreciated. Thanks
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
Post edited by ambiophonics on
Audioquest
or
BlueJean Cable
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Thanks - I will check those ones out
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio -
google is your friend,indeedIf you can't hear a difference, don't waste your money.
Try here: http://www.vhaudio.com/
High quality DIY supplies and some killer recipes, especially his Finesilver IC's"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Try here as well, good selection, good prices & excellent customer service.
http://www.fullcompass.com/ -
In the US for bulk cable it's:
Markertek
http://www.markertek.com/
and
Redco Audio
http://www.redco.com/default.asp
and
Have Inc.
http://store.haveinc.com/default.aspx -
Monoprice is a cheap favorite... also, sometimes Accessories4Less has some great discounts on mid-grade stuff.5.1 theater - Pioneer SC-07, Mirage OMD-CC center, 4 x Mirage Omnisats, Boston Acoustics VPS-210 sub
2.1 living room - NAD 7400 integrated, 2 x Platinum Audio Duos, MIT Terminator4 cables
2.1 bedroom- Arcam Solo, 2 x Mirage OMD-5's
FOR SALE - Genesis Servo-10 sub, Genesis Servo-12 amp; Martin Logan Dynamo sub; Mirage MM-6 sub; Harman Kardon DPR-1001 7.1 receiver -
I search ebay usually. Just got some 25' 12ga with Banana plug speaker cables, $29 each and very happy with them.---
Polk Studio Monitor 4.6 Series 2's, Polk RT1000p's, Polk LSi25's, Boston Acoustic VR-975's
Crown D-75, Crown CE1000, Crown CE2000 -
I just bought some bulk cable (although not IC cable) from Doug's shop. He's a member of our forum Helipilotdoug, screen name and he has very good prices and a good selection of cable and RCA ends for sale.
The link is here: http://www.douglasconnection.com/
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Thanks headrott - I'll check those out.2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
Depends on what you want, I found some great 4 conductor 12ga on ebay, but usually monoprice
